Cisco 6921 phone language
dshumake
Level 4
Level 4
I added a new site in columbia and change the user local to  spanish, columbia.
reset the phone, but it still come up as english.
ccm:  7.1.5
thanks
9 Replies 9
Chris Deren
Did you change the locale on the phones?  When firmware version are you using? Does the locale work on other phone models?
Chris
yes I change the user locale to spanish, colombia
yes the locale does work on  the 7945 phones
what firmware version?
Derrick,
Update your phones to latest firmware. this WILL fix your proble.
You need at least
cmterm-69xx-sccp.9-0-2-0.cop.sgn
Also make sure this is on ALL NODES have
cm-locale-es_ES-7.1.5.1200-1.cop.sgn
po-locale-es_ES-9.0.2.1000-1.cop.sgn
Please Kudos/rate if this help!
currently runing
fw:  9.3.3
i dont mind updating the fw. but adding the new locale file will require a cluster reboot.  that I can not do.
You don't need to add new locales, just upgrade firmware for the phones which does not require system reboot, only TFTP restart and phone reboot.
HTH,
Chris
Derrick,
I think that cuse of CSCue29440
https://tools.cisco.com/bugsearch/bug/CSCue29440
Take one of your phones to 9.0.2, at least just for testing!
Derrick,
where you issue fix the load i mention?
Where you able to get the phone on spanish?
