Cisco 7206VXR for CUBE feature
cristian.munoz
Level 4
Level 4
Hi All
Could someone recommend a version of IOS 12.4 for CUBE? The sho ver is :
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(12b), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 15-May-07 03:13 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
Router uptime is 19 minutes
System image file is "disk2:c7200-is-mz.124-12b.bin"
Cisco 7206VXR (NPE-G1) processor (revision C) with 229376K/32768K bytes of memory.
Processor board ID 35842938
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 300 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 300 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
2 Packet over SONET interfaces
509K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
TIA
Cristian.
9 Replies 9
cristian.munoz
Level 4
Level 4
Hi Guys
TIA
Cristian
Hi Cristian,
the image which u are using does not support CUBE.
I was navigating through Feature Navigator  and attaching the output of file.
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
I could find images which support CUBE but that are on version 15.x You can speak to Cisco SE to get the exact image name.
regds,
aman
Dear Aman
Thank you. Do you know the name of CUBE feature?
TIA
Cristian
Hi Cristian,
If u search by Feature and in box add CUBE , then, filter, u will get IOS images supporting CUBE.I am attaching the snapshot.
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Please find the URL which helps for ordering on ISR G2 with CUBE features
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/order_guide_c07_462222.html
I would advise u to speak to Cisco to help us in knwoing the exact images with featire set which supports CUBE functionality on 12.4.image train.
regds,
aman
Ok. Thanks for the information.
Who known how many session of Border Element supports the Cisco 7206vxr?
TIA
Cristian
Hi Cristian,
I tried to find out about the asked info on sessions but could not find other than what is available on FAQ
https://supportforums.cisco.com/docs/DOC-17964
If any expert from Cisco, could advise.
regds,
aman
Dear Aman
Thanks.I found the same information, due to this is that forum ask. I can´t found this information.
TIA
Cristian
Hi Aok,
the faq says :
Q4: What Platforms are supported for CUBE?
A: Cisco CUBE is an Integrated application with Cisco IOS software.
CUBE functionality is supported in Cisco 2600XM, 2691, Cisco ISR 2800, 3800 series, Cisco VXR 7200, Cisco XR 12000, AS5400XM Universal gateways and the Service Provider Gateways.
this means info is misleading.
regds,
aman
Amanso,
I am not sure since there is no documentation for this router. Since the faq says it is, then it probably is
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
