Dear All,I am running call manager 9.1Is it possible that i can records certain calls.If yes then please provide me the procedure.Regards,Malik
hi,I got paging going in my lab.any way I can control who can dial 41381 number?how can I control this if I don't want just anyont from picking up a phone and dialing 41381 and abusing?thanks.
Hello;I have a Siemens HiPath 3750 with TMS 2 card set with a protocol (S2M: Euro-ISDN PP WITH CRC4 Euronumeris = T2 + (ETSI) WITH CRC4) to make a connection with a cisco router 2610XM with IOS (c2600-ipvoice-mz.124-25) via an E1 card.WHat protocol s...
Hello,I have a 3825 router with 8 FXO ports running Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2). The problem we are facing is that after a call is placed through any of the FXO ports and the ca...
hi, recently i have changed the domain name of a VG224, before the change, all ports shows "registered" from the CUCM.after I changed the domain name from VG224 and CUCM, the VG224 can be registered to CUCM, and some ports can register too...only ser...
Hello All,I have a CUCM 9.1 cluster and all users use Extension mobility. There was no LDAP integration when the cluster was deployed long back and users use their 4 digit extension number as their phone login ID. (Local User IDs for 1400 users in CU...
Hi, with SIP phones it's possible to apply a codec voice class.Let's say I have the following voice class:voice class codec 1 codec preference 1 g722-64 codec preference 2 g711alawI can apply it for SIP phones, e.g. for pool 9:voice register pool 9....
Dear All,I am running call manager 9.1 and my gateway is registerd with MGCP.I need to know does call manager 9.1 supports caller id with MGCP gateway.Please guide me as i cant see callers' ID on my IP Phone.Regards,Malik.
Hi Sir,How can I change the Ringback tone on the CUCM 9.1?Is there any one change it?Please giving me some responses, thanks!!!Regards,Nicky
I have seen posts that suggest Tabsync will not work win Win7 because microsoft removed the WAB (Windows Address Book) in Win7. If this is true, has anyone found a way to Sync Outlook address book with Personal Address Book with Win 7?
I pulled this line below from the CuNotifier traces. Has anyone seen this error below before? if so, how to fix the MWI problem?"mwi extension=2942: doesn't need MWI update due lamp off and suspend-update set"
Is there one best way to associate directory numbers with CTI route points? Is it best to...1. Associate only one DN to each CTI RP, creating one CTI RP for each and every DN?...or..2. If the DNs server similar functions, can multiple DNs associated...
Hi AllWe have CUCM 7.1.5 and we are using the Cisco Attendant Console (built-in feature in CUCM) for operators. There is a one operator using 7960 IP Phone. It has 6 lines configured and those lines are assigned to pilot point. This operator doen't u...
HiIs it possible resume a call on my deskphone when i put a call on hold on cisco Jabber (Windows/ Iphone/IPad)?I have a problem with this but the opposite is possible.Thanks for you help.
Is there a way in Unity Connection 8.5 when using Single Inbox (Exchange 2007 EWS) to have the file name changed each time?Currently when I go into Outlook - Inbox each Voicemail has an attachment VoiceMessage.wavCustomer want's each file to be uniqu...
Subject | Author | Posted |
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 10:45 PM | ||
04-29-2025 03:01 PM | ||
04-29-2025 02:30 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
