cisco 7821/41 with 3350
mkhriesa
Is there any limitation for cisco 7821/41 with 3350? power ?
5 Replies 5
Mark Malone
7821s use IEEE 802.3af POE , the 3550 doesn't support this it was out before that type of POE was introduced
Are you having an issue getting them to come online in POE in the 3550 , you could use a power adapter instead
it keep restarting , so its the power not supporting?
Can you check if the command "sh power inline" has any outcome in your case?
Please post the result, if any
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
HI
Yes thats the issue irregular power draw making it unstable , if you use a power adapter take the power off the switch then
Phones too new for the older switch and is not backward compatible
George Sotiropoulos
You should use a Cisco Power Injector, model part number varies depending on the region you are located
George
