01-28-2019 04:56 AM - edited 03-17-2019 02:01 PM
Is there any limitation for cisco 7821/41 with 3350? power ?
01-28-2019 05:05 AM
01-28-2019 05:16 AM
it keep restarting , so its the power not supporting?
01-28-2019 05:21 AM
Can you check if the command "sh power inline" has any outcome in your case?
Please post the result, if any
George
01-28-2019 05:22 AM
01-28-2019 05:14 AM
You should use a Cisco Power Injector, model part number varies depending on the region you are located
George
