Cisco 7821 fireware upgrade
O.Zang
Hi Experts,
My sip Phones do not fallback to Call Manager and stay register with Survivable Remote Site Telephony.
It seem to be the bugg CSCvd03500. I would like to upgrade the phone to the latest version 12.
I have never upgraded ip phone with CUCM.
Please which one of the COP file and the zip file is good to go with regarding sip ip phone upgrade with CUCM ?
Thanks in advance for your help.
Zanga
Jaime Valencia
You simply need to download the cop file you want to use, install the new FW file, and then either change the device defaults or the phone load name at device level.
java
if this helps, please rate
7 Replies 7
Jaime Valencia
java
Hi Jaime,
Thanks for your reply. Do i need to do that on both of my CUCM ?
Zanga
You'll find that in the README for the FW you choose to install.
java
Hi we have a client using Avaya IPO R10 , they have Cisco 7821 with 3PCC firmware. Can help us how to configure the cisco phone so we can use it in avaya IPO..
The administration guide for 3PCC (MPP) phones can be accessed here:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/MPP/7800/english/adminguide/pa2d_b_7800-mpp-ag-11.pdf
Let us know which part would you need help in.
Thanks.
Thanks..
Need to know  how to define  ip address in cisco phone?
