Cisco 7861 - Inactive Load Failure Reason No Tftp server set
Austin3:16
Hello community ,
i have an issue with softkey in my cp7861 phone (pickup key not showing up), i want to update the firmware of the phone because I have doubts of the actual firmware after i install the new firmware and try to reset the phone an error message showing Inactive Load Failure Reason No Tftp server set.
Registration:unregistred
IPv4 Address:172.16.61.1
Active Load ID:sip78xx.12-8-1-0001-445
Inactive Load ID:sip78xx.12-0-1-11
Download Status:Failed
Requested Load ID:sip78xx-12-5-1SR3-74
Download Server:172.16.60.11
Inactive Load Failure ReasonNo Tftp server set
i dont have a subscriber.
Have you defined option 150 in your DHCP scope to point to the node where you run the TFTP services? As you wrote that you have no subscriber it would be the publisher.
Response Signature
Response Signature
Hello, i will check that and i will give you the update
