05-12-2009 05:36 AM - edited 03-15-2019 05:58 PM
Has anyone come across a problem where a 7921 IP phone has got stuck in headset mode where you cannot transmit or recieve voice to/from the phone.
I have tried upgrading the firmware but no joy. There seems no ducumentation about this, so is this a hardware fault or does anyone know a fix/workaround?
thanks for looking
Solved! Go to Solution.
05-12-2009 05:49 AM
Hi Paul,
This seems to indicate a Hardware problem :( Here is a similar thread that is addressed by Michael @ Cisco;
Hope this helps!
Rob
05-12-2009 05:49 AM
Hi Paul,
Hope this helps!
Rob
05-12-2009 05:52 AM
Rob,
You are really helping me here:-) thank you very much for you quick and speedy responses.
thank you.
very kind regards
Paul
05-12-2009 06:32 AM
Hi Paul,
You are most welcome my friend! Glad to be of some small help here.
Cheers!
Rob
02-16-2012 08:04 AM
Was there a resolution to this?
02-17-2012 11:08 PM
Zack,
If it's an hardware issue ( as discussed earlier in this thread ), the phone needs an RMA ( hardware replacement from Cisco ).
GP.
Pls rate helpful posts !!
