02-17-2011 12:30 AM - edited 03-16-2019 03:30 AM
I have got a Cisco 7940. I want to use it with SIP account. Can you help me to insert the SIP firmware?
02-17-2011 06:36 AM
You can delete it in CUCM (since it's currently a skinny phone) and readd it as a sip phone. After that, you will likely have to do a factory reset on the phone. You do that by power cycling it and holding down the # key. Wait for the lights to cycle on the Headset, Mute and Speaker buttons. Once the lights are cycling, press buttons 1, 2, 3, 4, 5, 6, 7, 8, 9, *, 0, # in that order. The phone will reset it's config, contact the DHCP server and start to download the firmware image from CUCM.
02-17-2011 09:45 AM
I do not have call manager...I have only the phone....
02-17-2011 11:52 AM
No help for me?
02-18-2011 05:37 AM
HELPPPPPPPPPPPPPPPPPPPPPPPPP!
05-23-2012 06:19 AM
I recently bought a brand new 7940G phone off ebay from a registered Cisco person who also supplied me the SIP firmware files so I can convert the phone to SIP because I am donating it to a charity and setting up a new network for them and running 3CX phone. From all the things I read it should be possible. This should help you Stefano but I still have not completed it to a working state so hope someone else can help too.
OS79XX.TXT and
SEPMacaddress.cnf.xml
Here is the log file from Pumpkin
[05/21/12 23:39:11] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:39:11] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:39:12] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:39:12] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:39:41] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:39:41] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:39:42] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:39:42] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:40:11] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:40:11] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:40:12] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:40:13] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:40:41] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:40:41] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:40:41] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:40:42] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:41:11] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:41:11] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:41:11] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:41:12] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:41:41] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:41:44] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:41:45] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:41:47] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:42:40] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:42:43] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:42:43] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:42:45] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
[05/21/12 23:43:13] 'OS79XX.TXT' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:43:16] Transfer of 'OS79XX.TXT' has successfully completed
[05/21/12 23:43:16] 'SEP0018BA722132.cnf.xml' of type 'octet' is requested from 192.168.2.7
[05/21/12 23:43:18] Transfer of 'SEP0018BA722132.cnf.xml' has successfully completed
The phone said "Loading software" (from memory)
On the phone I got an error that said something along the lines of "TFTP Size error P003-07-5-00" (from memory)
Then it just continued looping as shown above.
Can anyone please help me by suggesting what I can try next. I have burnt the midnight oil on this for the last week or so and really do not want to give up and buy dearer phones. Interestingly I bought a Yealink SIP phone and it worked within one minute on the 3CXPhone IP PBX which is running on the Small Business Server.
Maybe I should have bought the 7940 already changed to SIP!
Mark
