03-06-2011 05:40 AM - edited 03-16-2019 03:48 AM
I did try to update my firmware on Cisco 7941, I have upgraded the phone succesfully to 8.3.1 firmware, but this firmware didn't register to my IINET Voip router.
Thats why I tried to downgrade to the 8.0.3 firmware, because I read that this is working fine.
The firmware was loaded well from the tftp-server, but now I have the problem of the upgrading screen.
I tried already to restart the phone by pressing # and 1234567890*#, also tried for factory reset but this results in the same screen after starting up.
I see the phone is getting an IP-adress, but is not getting any files from the tftp-server again
I really need to get this fixed..Does anyone have any ideas?
I really need to get this fixed...
Vikrant
03-07-2011 04:52 AM
can you check on the phone what it says under
the status log on your phone's settings screen? maybe this
will give you a hint of why its failing to upgrade.
03-07-2011 08:40 PM
Thanks for your reply,
