Cisco 7960G SIP
bhouy
I trying to use a Cisco 7960G to work with a tird party PBX system call Spericall 6.x from NEC Sphere. Does anyone know how to set these phone to Sphere systems?
BH
paolo bevilacqua
Generally speaking, using cisco phones with non-cisco "softswitches" produces results that aren't great. This is also because Cisco never fully documented the .xml configuration file for the phones.
This said, if you want to see explanation and examples for the configuration file, go to voip-info.org, just type cisco 7960 in the search box.
