IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5820 Views
  • 14 replies
I have two sites with CUCME 7.0 routers. Site A has a PRI for outbound calls and a T1 connection to Site B. Site B forwards its outbound calls to Site A to go out the PRI.When Site B makes an outbound call the call connects, but after that it doesn...
gmgarrian by Level 4
  • 478 Views
  • 8 replies
I tried to setup a second admin on one of my Cue modules, once I login I receive this error "You are currently logged in without Administrator privileges, since the system has reached the maximum Administrators limit." Is the admin access a licensed ...
dvanzee by Level 2
  • 344 Views
  • 2 replies
Hi All, I am using BAT for "user device profile". I've created UDP template and subscribed it for two serivces: extension mobility and corporate directory. When I run BAT, these two services are not added to user device profile as subscribed services...
hi, i need to create some abbreviated numbers in a CME 7.0, so i was thinking to make some translation rules, example 456 - will make a call to a cell phone XXX_XXXXXX, but i have a problem, i am using cor list for the outbounds calls, and these tran...
Hi i have the following question:i want to connect 5 E1 PRI's on two 2821 voice gateways, i ordered:two VWIC2-2MFT-E1 cardsone VWIC2-1MFT-E1 cardenough PVDM2 cards on both voice gatewaysi will connect 3 E1's to one voice gateway and 2 E1's to the oth...
Hi,going through the CCIE LAB, i see sometimes used ntp master and others ntp peer, i looked into the command lookup but could not figure out!!!!Any one knows the difference?on the other hand do we need something else on the router to make it as ntp ...
twissam by Level 1
  • 1168 Views
  • 5 replies
Is there any way to implement consultive call transfer on FXS analog phone?As far as I know MGCP allows only blind one - analog phone user presses 'flash' gets dial tone, dials target number and the call gets forwarded immediately. Is is possible to ...
asigachev by Level 1
  • 735 Views
  • 4 replies
