Cisco 7962 phone not accepting firmware
Chojin
Well, halfway. We're switching from SCCP to SIP so was switching a phone. It gets an ip address, gets halfway through downloading files. But it just stops after apps42.9-4-2ES26.sbn, repeats the process, then reboots and the whole things starts over again.
1049345: Jun 13 20:14:38.822: TFTP: Looking for term62.default.loads
1049346: Jun 13 20:14:38.826: TFTP: Opened flash0:phone/7942-7962/term62.default.loads, fd 4, size 666 for process 135
1049347: Jun 13 20:14:38.838: TFTP: Finished flash0:phone/7942-7962/term62.default.loads, time 00:00:00 for process 135
1049348: Jun 13 20:14:39.722: TFTP: Looking for jar42sip.9-4-2ES26.sbn
1049349: Jun 13 20:14:39.726: TFTP: Opened flash0:phone/7942-7962/jar42sip.9-4-2ES26.sbn, fd 4, size 1765313 for process 135
1049350: Jun 13 20:14:46.670: TFTP: Finished flash0:phone/7942-7962/jar42sip.9-4-2ES26.sbn, time 00:00:06 for process 135
1049351: Jun 13 20:14:52.046: TFTP: Looking for cnu42.9-4-2ES26.sbn
1049352: Jun 13 20:14:52.046: TFTP: Opened flash0:phone/7942-7962/cnu42.9-4-2ES26.sbn, fd 4, size 581755 for process 135
1049355: Jun 13 20:14:54.430: TFTP: Finished flash0:phone/7942-7962/cnu42.9-4-2ES26.sbn, time 00:00:02 for process 135
1049356: Jun 13 20:14:56.966: TFTP: Looking for apps42.9-4-2ES26.sbn
1049357: Jun 13 20:14:56.966: TFTP: Opened flash0:phone/7942-7962/apps42.9-4-2ES26.sbn, fd 4, size 4638412 for process 135
1049358: Jun 13 20:15:15.258: TFTP: Finished flash0:phone/7942-7962/apps42.9-4-2ES26.sbn, time 00:00:18 for process 135
And that's it. term62.default shows dsp42.9-4-2ES26.sbn should be next. Did a couple of factory defaults on the phone without luck. Any ideas what I should look for in why it's stopping here?
Thanks!
M02@rt37
Hi @Chojin
Do you re try to xtract again the archive firmware tar file?
Best regards
Leo Laohoo
From what version is the phone operating from? What hardware version is the phone?
The phone was 9-4-2 SSCP before. I'm switching it to 9-4-2 SIP. There was no problem upgrading the phone to a newer SCCP firmware. So I'm assuming the hardware version can handle 9-4-2. I'll try re downloading the firmware then uploading fresh to the router.
Thanks!
M02@rt37
Hi @Chojin
Best regards
