Cisco 7965G Phones and Ring Central
Freddie Eisa
We are looking to migrate to a 3rd party SIP vendor from Call Manager. I need to get the phones migrated to the 3rd party. Has anyone had any experience with this? If so could you share an XML config? What I have so far is refusing to connect thanks. Any 3rd party SIP vendor may be similar.
Manish Gogna
Hi Freddie,
You may check the following links
https://supportforums.cisco.com/discussion/10998266/sepcnfxml-file-needed-3rd-party-pbx
http://www.888voip.com/configuring-cisco-7975-ip-phones-for-sip/
https://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
Manish
