01-28-2015 12:27 AM - edited 03-17-2019 01:44 AM
Hello
I have cisco ip phone 8831.
The phone won't register .
I have cucm version 8.5.1.15900-4 and I installed device pakage and I made reset to pub and sub.
The phone accept ip but won't register even though we configured tftp manually
any idea?
01-28-2015 01:43 AM
If the cluster has been rebooted after applying the device pack then please provide a parallel set of captures from cucm and the IP phone after its plugged in till the time it gets stuck on registering.
https://supportforums.cisco.com/document/44741/collecting-packet-capture-cisco-ip-phone
https://supportforums.cisco.com/document/44376/packet-capture-cucm-appliance-model
Manish
01-28-2015 04:47 AM
In addition to what Manish has said,can u share the show version active from server on which u have uploaded Device Pack ?
regds,
aman
01-28-2015 05:03 AM
admin:show version active
Active Master Version: 8.5.1.15900-4
Active Version Installed Software Options:
cmterm-7942_7962-sccp.9-2-3.cop
cmterm-7942_7962-sccp.9-3-1SR2-1.cop
cmterm-7942_7962-sccp.8-5-4.cop
cmterm-7937-1-4-5-7-SCCP.cop
cmterm-7942_7962-sccp.9-1-1SR1.cop
cmterm-8831-sip.9-3-3-5.cop
cmterm-iphone-install-100222.cop
cmterm-7942_7962-sccp.8-5-2.cop
cmterm-8831-sip.10-3-1-16.cop
cmterm-7942_7962-sccp.9-3-1-1.cop
cmterm-7916.1-0-4.cop
cmterm-devicepack8.5.1.17131-2.cop
01-28-2015 05:15 AM
I can see the firmware cmterm-8831-sip.9-3-3-5.cop compatible with uploaded Device pack cmterm-devicepack8.5.1.17131-2.cop in show version shared by you.
Did u reboot the server?
regds,
aman
01-28-2015 05:20 AM
Yes, I made reset.
01-28-2015 05:30 AM
can u try ping 8831 IP address from CLI of PUb/Sub to check reachability?
utils network ping x.x.x.x
regds,
aman
01-28-2015 05:34 AM
hope u have DLUs to register this phone.
regds,
aman
01-29-2015 01:13 AM
We have more than enough. Can you please refer to the image attached in the
first post ? It seems to be red X instead of the little image of the phone.I thhink it might be related .
Regards ,
01-29-2015 01:31 AM
I can few bugs related to 9.3(3) firmware.Can u try upgrading to cmterm-8831-sip.10-3-1-16.cop.sgn and check if it works?
CP-8831 can't be registered with re-connecting cable when using AC power
CSCuj43533
Description
Symptom:
CP-8831 unable to be registered automatically with re-connecting the cable when using AC power
Conditions:
- using AC power
- DHCP disable
- re-connect the cable between the phone and the switch
8831 accepts untagged DHCP Offer after sending Discover on Voice VLAN
CSCup90022
Symptom:
- 8831 displays "Phone not registered"
- 8831 is getting an IP address on a VLAN other than the voice VLAN
Conditions:
- Phone's switchport is configured with both "switchport voice vlan" and "switchport access vlan"
- Two different DHCP servers are used for the data and voice VLANs, and the DHCP servers are not VLAN aware
Workaround:
- Change the switchport's access VLAN to be the voice VLAN
- Remove the voice VLAN from the switchport facing the data VLAN's DHCP server
regds,
aman
01-29-2015 12:36 AM
yes I have ping.
01-29-2015 12:51 AM
DO u have enough licenses on Cal Manager?
when u connect different model phone on same port where 8831 is connected, does that work.
regds,
aman
01-29-2015 01:07 AM
yes
01-29-2015 01:37 AM
As you are adding the phone manually, are you assigning a DN to the IP phone as well? If not , please try and do so. As most other parts related to config and network have been covered on this post, it would be better to post the packet captures as requested earlier to get to a resolution quickly.
Manish
06-21-2019 07:45 AM
Have you deleted the ITL file?
