Cisco 8851 add on module
andrewokeefe
According to the 8851 data sheet you should be able to power 2 add on modules using 802.3at POE, as long as the phone version is v08 or higher.
We are unable to get the second module to power up, anyone had this issue ?
11 Replies 11
Brandon Buffin
What type of switch? Is it capable of 802.3at. Can you post "show power inline <port>"?
Brandon
Hi Brandon
the switch is a 3850
show power inline gi2/0/44
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi2/0/44  static off        30.0    n/a                 n/a   30.0
CORE_3850_174.16#show power inline gi2/0/43
                            (Watts)
OK. Should work. You have confirmed on the label on the back of the phone that the hardware is V08 or later?
yes, we have tried 3 8851 in all, version v08, but none work, unfortunately we haven't got any newer than v08 to test with
Have you verified that the both KEMs work if you use a power cube? Might also be worth opening a case with TAC.
Hi Brandon
Yes they work ok with a power cube, trouble is we have a few to roll out and we didn't buy any extra power cubes ,assumed they should work;-)
I will get a TAC case raised.
Thanks for you help
Rob Huffman
Hi Andrew,
The way I see the notes on the attached doc is that 2 KEM's with an 8851 require a Powercube 4;
There is also a document defect bug that relates to some of PoE info;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd84704
Table 3 Key Expansion Module Power
Cisco IP Phone 8851 and 8851NR
Cisco IP Phone 8861
Cisco IP Phone 8865 aand 8865NR
Accessories
802.3af PoE
802.3at PoE
Cisco IP Phone Power Cube 4
802.3af PoE
802.3at PoE
802.3af PoE
802.3at PoE
1 KEM
Supported
KEM will power up as 802.3at is backwards compatible with 802.3af.
Supported
Not supported
Supported
Supported
Not supported
Supported
Supported
2 KEM
Not supported
Not supported
Supported
Not supported
Supported
Supported
Not supported
Supported
Supported
3 KEM
Not supported
Not supported
Not Applicable
Not supported
Supported
Supported
Not supported
Supported
Supported
1 KEM + tablet charging
Not supported
Not supported
Not supported
Not supported
Supported
Supported
Not supported
Supported
Supported
2 KEM + tablet charging
Not supported
Not supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
3 KEM + tablet charging
Not supported
Not supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Smart phone charging (No KEM attached)
Yes
Yes
Not supported
Yes
Yes
Not supported
Yes
Yes
Yes
Tablet charging
Yes
Yes
Not supported
Yes
Yes
Not supported
Yes
Yes
Yes
From
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series/P881_BK_C136782F_00_cisco-ip-phone-8811-8841_chapter_0111.html#IP8K_TP_K8B7A60A_00
Rob,
That was true of older 8851 phones. Did you see the note here regarding V08 and newer phones:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8800-series-key-expansion-module/datasheet-c78-732356.html
Brandon
Hey Brandon,
Good info my friend! (+5). I'll keep looking for a better answer here.
Cheers!
Rob
Amit23
Level 4
Level 4
Hello Andrew,
i saw your post and we are facing similar to your issue.
we have one 8851 with 1 KEM audio 28 button but it is not powering up when connection.
in phone accessories it is showing disabled by administrator.
I checked all required option and enabled in CUCM but still no success.
Please let me know if need any other step for it.
we have cucm 11.5.X and connected audio 28 button KEM with power cube-4 .
Warm Regard's
Amit Sahrma
hi Amit, did you manage to resolve the issue , am in same situation
