12-21-2015 03:27 PM - edited 03-18-2019 11:44 AM
We have noticed that when we place 8861 phones behind a VPN router the phones can no longer download templates or changes. They work just fine otherwise. It does not appear to be a port blocking issue so we are wondering if it might be related to MTU size. On call manager it says it can't access TFTP but we have 69 udp and tcp open. Has anyone experienced this? Any ideas on what we can try?
12-21-2015 04:48 PM
12-22-2015 12:10 PM
Marcelo - Thank you for the information. We did add the few that were missing, however the same problem exists.
Do you have any other ideas?
Thanks.
CJ
12-23-2015 08:46 AM
please, check in the following link: Port Description, for the TFTP and Endpoint info (for example: TCP 6970).
Hope this helps
12-23-2015 10:51 AM
Hi Cj,
Incase you are using ASA for vpn then refer to below post
https://techzone.cisco.com/t5/ASA-Virtual-Private-Network-VPN/AnyConnect-VPN-Phone-IP-Phones-ASA-and-CUCM-Troubleshooting/ta-p/142954
Thanks!
Kunal
