Cisco AnyConnect and Android devices
david-lima
Level 4
Level 4
Hi guys, does any one know if Cisco Jabber and Cisco AnyConnect are supported in the following devices:
- GALAXY Note 10.1 N8000 with Android Ice Cream Sandwich v4,0
- SAMSUNG SGH-I957 GALAXY TAB 8.9 LTE 3G with Android OS v3.2 (Panal)
I would appreciate your comments and experience.
Thanks a lot.
David
8 Replies 8
Anas Abueideh
Level 9
Level 9
i am using galaxy note and i have any connect.
it worths to download it from the play store and give it a try
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
Hi Anas, thanks a lot for your response.
Do you have installed Cisco Jabber also?
To intall Cisco AnyConnect, do you have to make you a "root" of the device?
I'm asking that 'cuase I'm planning to buy a couple of GALAXY Note 10.1 N8000 devices at least, and I wanna make sure about that.
Thanks again
David
Hi David,
I installed Cisco Jabber also. for Any Connect I didn't use root of the device.
AnyConnect and Cisco Jabber were installed as any other application.
Cisco Jabber was working over vpn also
Me device is Galaxy Note, the Android version is ice cream sandwich
Anas
Hi David,
no worries, your devices are fully supported and work as expected.
Martin
Hi everyone,
would someone be so kind and describe the necessary credentials that must be set to get Jabber to work. I can connect with Anyconnect with my Galaxy Note 10.1, but I get stuck with the Jabber part.
What to put in in brackets for DEVICE ID and Server address?
THX everyone
Drejč
you need to add Dual phone for android in the CCM. device name should statrt with "BOT" , so the device ID would be BOTxxxx. when configure configure your Jabber on your phone you need Device ID and TFTP address, don't use digest authentation. please fine the below admin guide for android
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Android/8_6/JABA_BK_A940B90D_00_jabber-for-android-admin-guide_chapter_00.html
Anas
please don't forget to rate the helpful posts
Hi Drejč.
If you will use mobile data network service to connect with anyconnect and than with Jabber, remember to allow the use of mobile data network under Jabber settings in order to register your phone.
Carlo
Please rate all helpful posts "The more you help the more you learn"
DanatShekhe
On my Note 10.1 Jabber is not supported on ICS 4.1.2. Also I tryed to install it on ICS 4.0 and 4.1.0 4.1.1 - same not working
