Cisco ATA 191 Line 2 not registered
iptsupport
Level 4
Level 4
Hello ,
I have ATA191 that line 1 is registered but
line 2 is not registered.
line 1 mac (example BBAAAAAAAAAA
line 2 mac (example): AAAAAAAAAA01
my CUCM version is 11.5
any idea?
b.winter
You need to enable the second port first. In the configuration page in CUCM of the first port, enable "Line 2 Support".
b.winter
@iptsupport Any update here?
gfolens
Level 4
Level 4
So If I understand correctly you need to add a second ATA phone device in CUCM with MAC address +1 to be able to use and register the 2nd line.
Correct. The two ports identifies as separate devices in CM.
Response Signature
