Cisco ATA 191 web access refused to connect
lana1
Cisco ATA191-K9 is working but web access says refused to connect!
Phone Information:
Model Number: SPA122
IPv4 Address: 10.100.....
MAC Address: BCD....
Active Load: SPA122.0-0-0-.loads
Last Upgrade: Upgrade Failed
Active Server:
Active Server Type: Spark Call
Stand-by Server:
Stand-by Server Type:
13 Replies 13
Is this ATA 191, it says SPA122.
Could you please explain a little more about your setup ?
Response Signature
Hi Nithin
Pls. see below ssh config from device:
Phone Information:
Active Server:
Stand-by Server:
Device is connected to voice Vlan and only can be seen in Call Manager!
But it is working as analog line!
Web enabled but refuses to connect!
Geovani
Silly question, but have you tried both http and https?
Understand your question!
Yes of course!
Geovani
If this is a SPA122, it has two ports. Internet and Ethernet. HTTP traffic on the Internet port is disabled by default, but if you connect your pc/laptop to the Ethernet port, the SPA122 should assign you and IP address on the 192. range.
I don't have much experience with SPA122, but on the ATA192 that's the case. When connecting to the Ethernet port, you will get an IP address on 192.168.15.X by default, and the ATA IP is usually 192.168.15.1.
Hi Geovani
Ip address is fine, I can see in CUCM, web enabled both http and https, but cant get into.
it exactly looks as below:
https://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-190-series-analog-telephone-adapters/datasheet-c78-739907.html
or
https://www.tonitrus.com/en/phones/cisco/accessories/ata-analog-adapter/10230882-003-cisco-ata191-k9-cisco-ata-191-voip-telefonadapter-100mb-lan/
when SSH to device I can see
Phone Information:
Active Server:
Stand-by Server:
From Ssh message,  its shows model as SPA122. You can find the model number from the device itself and If its ATA 191, you are effected with the BUG ID CSCvp92985.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp92985/?rfs=iqvred
Second thing,  what's the status on CUCM for this device ? is it shows registered ?
Response Signature
Device works, registered, ip address, but no web access refused.
if its a 191, you are effected with the BUG ID CSCvp92985. Fix this Bug first.
Response Signature
Hi Nithin
I followed bug id and it sends to me to these files for download.
ATA 191 load signed COP file - Compatible CUCM Versions: 9.1+
cmterm-ata191.12-0-1-0301-002.k3.cop.sgn
Advisories
18-Nov-2020
21.20 MB
ATA 191 Alternative firmware format
cmterm-ata191.12-0-1-0301-002.zip
Advisories
18-Nov-2020
21.20 MB
The question is where to upload these files, in Tftp server, or?!!
To upgrade it though CUCM use cmterm-ata191.12-0-1-0301-002.k3.cop.sgn file. From  CUCM os admin page. Install the COP on all node. Change the default ata load to the new and restart the ATA.
Response Signature
Nithin
Upload file done but restarting doesn't help.
Where do I need to change the default ata load to the new load!
Thank you
firmware loaded on ata 191
now I can see in Wireshark
Software version: ATA191.12-0-1-0301-002.loads
But there is problem now!
Device is not registering at all and
restarts every one minute by itself!
I can see that when connected device remembers the ip address from the previous!
