Cisco Attendant Console Enterprise ver 9
4.1.2. Microsoft SQL Server Obsolete Version (mssql-obsolete-version)
Description:
An obsolete version of the Microsoft SQL database server is running. Note: When the support period ends for a Microsoft SQL Server
product, no further patches will be provided even for serious security problems.
Is it possible to just upgrade the SQL version that is used with the Attendant console or can there be DB problems?
Best Regards
Chris Deren
You can upgrade SQL server to any supported version by the CUEAC version, see the data sheet for supported SQL server versions:
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-attendant-console-enterprise-edition/data_sheet_c78-520987.html
Shashank Mahajan
Which SQL version is currently installed? Are you planning to upgrade from SQL express edition to a standard or enterprise version?
Cisco Unified Attendant Console Version 9.1 supports only the following databases:
– Microsoft SQL Server 2008 Express, Standard or Enterprise (32-bit or 64-bit)
– Microsoft SQL Server 2008 R2 Express, Standard or Enterprise (32-bit or 64-bit)
