Cisco BE6000 Server models confusion
Chhabi Thapa
Hello everyone,
One of my client is planning to deploy Cisco BE6000M.As i checked the datasheets there were three models Cisco BE6000M,Cisco BE6000H and Cisco BE6000S.
Is Cisco BE6000H/M a server platform and Cisco BE6000S a module to be integrated with the Cisco 2921 router only ?
Jaime Valencia
Yes, M and H are UCS servers, S is a 2921 ISR with UCS-E
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/collaboration-virtualization-hardware.html
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime for quick response.So instead of 2921 ISR can i use 2951 ?
No, you cannot. All the 6K options are TRC's.
A TRC is a fixed configuration, if you deviate in any way, it's no longer a TRC.
java
Thank you Jaime.I realy appreciate your help.
