Cisco BE6000S license & Installation Questions
Hi all,
I received the Below using edelivery which have to be deployed in Cisco BE6000S (BE6S-FXO-M2-K9):
My questions:
1- Are all/some licenses came installed in the BE6K-S router when purchased or i have to install them using PAK in CUCM & Unity.?
2- As it is BE6KS which has fixed application, how to use the below Telepresence VCS-Expressway licenses? OR will be installed in other server?
3- refer to attached plz,what is the mean of unfulfilled, do these need to be installed in the CUCM??
4- need configuration guide for VCS & Jabber in CUCM BE6K-S.
5- is the quick start guide for BE6000S & installation guide sufficient for first step to deploy or you have other advised resources?
thanks in advance
Product ID (SKU)
Description
Qty
Carton/Cust Ref Line Note
R-CBE6K-K9
Cisco Business Edition 6000-Electronic SW Delivery-Top Level
Register Claim Certificates (PAKs)
BE6K-UCL-VM
Cisco Business Edition 6000- Voicemail/Unified Messaging Lic
45
BE6K-UCL-ENH
Cisco Business Edition 6000 - Enhanced User Connect License
45
BE6S-SW-11.5
Business Edition 6000S v11.5 export restricted software
CUCILYNC-CLNT-UWL
Cisco Unified Comm Integration for Lync for CUWL only
IPC8-CLIENT-UWL
IP Communicator 8.x for CUWL only
JAB-IPH-CLNT-UWL
Jabber for iPhone CUWL Only
JAB-ADR-CLNT-UWL
Jabber for Android CUWL Only
JABBER-DESKTOP
Jabber for Desktop for PC and Mac
JABBER-TABLET
Jabber for iPad and Android Tablet
CIPC-UWL-RTU
CIPC UWL Right to Use Certificate
CUCILYNC-UWL-RTU
CUCILYNC UWL Right to Use Certificate
JAB-ADR-RTU
Jabber for Android Right to Use
JAB-IPH-RTU
Jabber for iPhone Right to Use
LIC-EXP-GW
Enable GW Feature (H323-SIP)
LIC-EXP-E
Enable Expressway-E Feature Set
SW-EXP-8.X-K9
Software Image for Expressway with Encryption, Version X8
BE6K-PAK
Cisco Business Edition 6000 - PAK - Single Fulfillment
LIC-EXP-SERIES
Enable Expressway Series Feature Set
EXPWY-VE-C-K9
Cisco Expressway-C Server, Virtual Edition
LIC-EXP-TURN
Enable TURN Relay Option
LIC-EXP-AN
Enable Advanced Networking Option
LIC-SW-EXP-K9
License Key Software Encrypted
EXPWY-VE-E-K9
Cisco Expressway-E Server, Virtual Edition
BE6K-UXL-START
BE6K Starter Pack - Single Fulfillment Enforcement
LIC-EXP-E-PAK
Expressway Series, Expressway-E PAK
JAB-GUEST-RTU-K9
Jabber Guest Right to Use
JABBER-TABLET-RTU
Jabber for Tablet Right to Use
JABBER-DSK-K9-RTU
Jabber for Desktop Right to Use
BE6K-START-UCL35
BE 6000 - UCL Starter Bundle with 35 Enh and 35 VM Licenses
JABBER-GUEST
Jabber Guest Session
UCXN-11X-SCPORTS
BE6K - Unity Connection 11x - VM Speech Connect Ports
UCM-11X-ENH-UCL
BE6K UCM 11X Enhanced User Connect Lic - Single Fulfillment
45
UCN-11X-VM-UCL
BE6000 Unity Connection 11x Basic Voicemail License
45
LIC-EXP-DSK
Expressway Desktop Endpoint License
80
BE-11X-UCL-STR
BE6000 v11 UCL Starter licenses
6 Replies 6
Jaime Valencia
1 Licensing AFAIK is the same, you'll need to use PLM, as with any other deployment
2 The set of applications on the BE6KS is fixed, you cannot change or swap the applications, if you want some other app(s) you need a separate server for them.
4 Same configuration guides apply to any deployment, there are no special config guides for the apps on a 6KS, review the VCS and Jabber docs on cisco.com for the config.
java
if this helps, please rate
Thanks too for you Mr. Jaime,
but i didn`t understand answer for number 1, meaning for below.
Can you explain more,plz
Hi Mohammed,
PLM is Prime License Manager which comes inbuilt on the CUCM v 11.5 or you could install it separately. This PLM manages the CUCM licenses. You cannot install licenses on the CUCM directly and has to upload the licenses in PLM.
Rajan
HARIS_HUSSAIN
    • You have to Install the PAK for CUCM and Unity. None is preinstalled except the ESXi License.
    • Depending on you Server CPU Density there are fixed amount of Application Supported on Each Server Refer Below Link. So you can install Expressway on Same Hardware if resoucese are available as per below guide.
    • http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps11369/solution_overview_c22-727987_ps13641_Product_Solution_Overview.html
    • Table 2. Co-resident Collaboration Applications on Cisco Business Edition 6000
      Application
      Capacity
      vCPU
      vRAM
      vDisk
      Distribution Type
      Maximum capacity
      Medium-density server
      Four unified communications applications plus one provisioning application
      8
      32 GB
      4x 500 GB
      High-density server
      Eight unified communications applications plus one provisioning application
      16
      48 GB
      8x 300 GB
    • Unfulfilled means you have to install this licenses on CUCM, Expresssway etc servers.
4- need configuration guide for VCS & Jabber in CUCM BE6K-S.r
 Search for configuration guide as per Expressway Version you are installing, doesn't vary based on Hardware.
         You might need to look at other resources for CUCM,CUC, Expressway Installations.
Hi Haris,
Thanks a lot for your detailed answers.
I think Question 2, the customer purchased the wrong server which is S (router based) in which the Expressway can only be installed high or medium density.
You cannot install on the same server as you have got a BE6S, You have to install it on any other supported servers on the list or have to procure any UCS servers.
Please check the below link for more information on the compatible servers for expressway:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-expressway.html
Rajan
