Cisco Call Manager 9.1
skakfinn1
     I have installed call manager 9.1 (UCSInstall_UCOS_9.1.2.11900-12) on VMWARE workstation 10.0 in my Lab, after the installation went fine when I am logging to the call manager using the GUI and CLI I get this error.
ERROR-UNSUPPORTED: Partitions unaligned
Your help will be appreciated
2 Accepted Solutions
Hi Syed.
Did you use an OVA Template to deploy your CUCM?
Please have a look to the following doc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_2/CUCM_BK_C9FFFCD0_00_cucm-release-notes-912.pdf
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Read this thread , this can help you to find answer.
https://supportforums.cisco.com/thread/2234742
Manish
Rate all the helpful post.
Hi Syed.
Carlo
I need to understand what does the error means and what if its left alone ? I havent used the OVA template, I made a customized virtual machine using Vmware workstation 10, if I would have used ESXI i would have used the OVA template.
Message was edited by: syed khan
Manish
