12-06-2013 10:59 AM - edited 03-16-2019 08:45 PM
I did setup SIP trunking between Cisco Call Manager Express 9.0 to Lync 2010 Std, I can call from Lync to CME, but i cannot call from CME to Lync
(Call from 7011(CME Phone) to 8007(Lync Phone))
Below is my configuration:
hostname BMT-HCM-R2911-VoIP
boot-start-marker
boot-end-marker
enable password 7 12485744465E5A
no aaa new-model
clock timezone GMT+7 7 0
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
no ip domain lookup
ip cef
voice-card 0
voice service voip
ip address trusted list
ipv4 10.0.0.0 255.0.0.0
ipv4 172.16.0.0 255.255.0.0
ipv4 192.168.0.0 255.255.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
header-passing
error-passthru
asserted-id pai
midcall-signaling passthru
privacy-policy passthru
no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-48
codec preference 4 g722-56
codec preference 5 g722-64
codec preference 6 g723ar53
codec preference 7 g729br8
codec preference 8 g729r8
codec preference 10 g728
voice class sip-profiles 3
request INVITE sip-header Diversion remove
voice class custom-cptone Disconected
dualtone disconnect
frequency 425 425
cadence 500 500
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice translation-rule 4000
rule 1 /\(8...\)/ /+\1/
voice translation-profile LYNC_ADD_PLUS
translate called 4000
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
param number-of-hunt-grps 1
paramspace english index 1
param menu-timeout 1
param aa-pilot2 6012
param handoff-string aa
param dial-by-extension-option 3
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 6011
param max-extension-length 4
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 700
param voice-mail 5003
param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
param queue-len 15
param aa-hunt10 8552
param aa-hunt1 6100
param aa-hunt2 6101
param number-of-hunt-gprs 3
param queue-manager-debugs 1
license udi pid CISCO2911/K9 sn FGL1547116N
hw-module pvdm 0/0
username admin privilege 15 password 7 06575D72181B5F
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description "Connected to Virgor"
ip address 172.16.0.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description "Conneted to S2960-001"
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.16
encapsulation dot1Q 16
ip address 172.16.16.249 255.255.255.0
interface GigabitEthernet0/1.17
encapsulation dot1Q 17
ip address 172.16.17.249 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.0.1
access-list 1 permit 172.16.16.0 0.0.0.255
access-list 1 permit 172.16.17.0 0.0.0.255
tftp-server flash:wellcome_bmt.au
tftp-server flash:en_bacd_welcome.au
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone Disconected
timeouts interdigit 5
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
timing min-ring 62
connection plar 7000
description >>>FXO Port 0 for In/Out Calling<<<
caller-id enable
voice-port 0/0/1
timeouts ringing 5
description >>>FXO Port 1 for In/Out Calling<<<
caller-id enable
voice-port 0/0/2
timeouts ringing 5
description >>>FXO Port 2 for In/Out Calling<<<
caller-id enable
voice-port 0/0/3
timeouts ringing 5
description >>>FXO Port 3 for In/Out Calling<<<
caller-id enable
mgcp profile default
dspfarm profile 1 conference
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
shutdown
dial-peer voice 3000 pots
description >>>CO Trunk with PSTN FXO 0<<<
translation-profile incoming INCOMING
preference 1
service aa
destination-pattern 9T
direct-inward-dial
port 0/0/0
dial-peer voice 3001 pots
description >>>CO Trunk with PSTN FXO 1<<<
preference 2
direct-inward-dial
port 0/0/1
dial-peer voice 3002 pots
description >>>CO Trunk with PSTN FXO 2<<<
preference 3
service aa
port 0/0/2
dial-peer voice 3003 pots
description >>>CO Trunk with PSTN FXO 3<<<
preference 4
port 0/0/3
dial-peer voice 552 voip
description **Incoming Call from LYNC**
b2bua
session protocol sipv2
session target ipv4:172.16.17.15:5068
session transport udp
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip block 183 sdp absent
dtmf-relay rtp-nte
no vad
dial-peer voice 551 voip
description ** SIP Trunk to Lync Core **
destination-pattern 8...
notify redirect ip2pots
voice-class sip early-offer forced
voice-class sip profiles 3
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
no vad
sip-ua
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 300
ip source-address 172.16.16.249 port 2000
timeouts interdigit 2
system message BAN MAI TECHNOLOGIES CORP.
time-zone 25
date-format dd-mm-yy
max-conferences 5 gain -6
call-forward pattern .T
transfer-system full-consult
transfer-pattern .T
fac standard
ephone-dn 1 dual-line
number 7000
label Tran Thi Dai Nguyen
name Nguyen. Tran
ephone-dn 2
number 7010
label Nguyen Thi My Tho
name Tho. Nguyen
ephone-dn 3
number 7001
label Truong Hoai Tin
name Tin. Truong
ephone-dn 4
number 7003
label Trinh Thi Tuyet Trinh
name Trinh. Trinh
ephone-dn 5
number 7007
label Huynh Trong Nhat Minh
name Minh. Huynh
ephone-dn 6
number 7005
label Tran Le Bao
name Bao. Tran
ephone-dn 7
number 7004
label Tran Thuy Minh Trang
name Trang. Tran
ephone-dn 8
number 7006
label Dang Nguyen Ha Khuyen
name Khuyen.Dang
ephone-dn 9
number 7008
label Meeting Room
name Meeting Room
ephone-dn 10
number 7009
label Dieu Vinh Cuong
name Cuong. Dieu
ephone-dn 11
number 7999
label Le Gai Dang
name Gai.Dang
ephone-dn 12
number 7002
label Nguyen Van Nam
name Nam. Nguyen
ephone-dn 13
number 7011
name Huynh Trong Nhat Minh
ephone-dn 14 dual-line
number 7012
label TEST
name TEST
ephone 1
device-security-mode none
mac-address 24B6.5745.588E
type 7942
keep-conference endcall
button 1:1
ephone 2
mac-address 24B6.57B0.A52D
type 7942
button 1:2
ephone 3
type 7942
ephone 4
mac-address 24B6.5744.BE4D
type 7942
button 1:4
ephone 5
mac-address 24B6.57B0.7562
type 7942
button 1:5
ephone 6
mac-address 24B6.5744.18C0
type 7942
button 1:6
ephone 7
mac-address 24B6.57B1.2DD3
type 7942
button 1:7
ephone 8
mac-address 08D0.9F9F.9D49
type 7942
button 1:8
ephone 9
mac-address 08D0.9F9F.9B8E
type 7942
button 1:9
ephone 10
mac-address 08D0.9F9F.9A27
type 7942
button 1:10
ephone 11
mac-address 5CAC.4C3D.B4A0
type CIPC
ephone 12
mac-address 08D0.9F9E.E5EE
type 7942
button 1:12
ephone 13
description "Huynh Trong Nhat Minh "
mac-address 9439.E5DF.215B
type CIPC
button 1:13
ephone 14
mac-address 000C.2932.CA14
type CIPC
button 1:14
ephone-hunt 1 sequential
pilot 1000
list 7001
ephone-hunt 2 sequential
pilot 1001
list 7001
ephone-hunt 6 sequential
pilot 6101
list 7001
Debug on CME for the issue:
BMT-HCM-R2911-VoIP#
Dec 6 18:56:44.630: //-1/FC2E5797A4EE/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=7011
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Dec 6 18:56:44.630: //-1/FC2E5797A4EE/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2D737304, Call Info(
Calling Number=7011,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20021, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Dec 6 18:56:44.630: //-1/FC2E5797A4EE/CCAPI/ccCheckClipClir:
In: Calling Number=7011(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=7011(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Dec 6 18:56:44.630: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 6 18:56:44.630: :cc_get_feature_vsa malloc success
Dec 6 18:56:44.630: cc_get_feature_vsa count is 2
Dec 6 18:56:44.630: :FEATURE_VSA attributes are: feature_name:0,feature_time:842527176,feature_id:15989
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=7011(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/cc_process_call_setup_ind:
Event=0x2C669AC8
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/ccCallSetContext:
Context=0x323B678C
>>>>CCAPI handed cid 19802 with tag 20021 to app "_ManagedAppProcess_Default"
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/ccCallSetupAck:
Call Id=19802
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=19802
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/ccCallReportDigits:
(callID=0x4D5A, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=19802
Dec 6 18:56:44.630: //19802/FC2E5797A4EE/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2D737304, callID=0x4D5A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x2D737304, Call Id=19802
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=2000(ms))
Dec 6 18:56:44.938: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_begin:
BMT-HCM-R2911-VoIP#Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=19802, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x31D9B8, Rtp Expiration=0x0
Dec 6 18:56:44.938: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_end:
Source Call Id=19802, Digit=8, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Dec 6 18:56:44.986: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_begin:
Source Call Id=19802, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x3256B8, Rtp Expiration=0x0
Dec 6 18:56:44.986: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_end:
Source Call Id=19802, Digit=0, Duration=100,
Dec 6 18:56:45.198: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x32D3B8, Rtp Expiration=0x0
Dec 6 18:56:45.198: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_end:
Dec 6 18:56:45.406: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_begin:
Source Call Id=19802, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x3350B8, Rtp Expiration=0x0
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/cc_api_call_digit_end:
Source Call Id=19802, Digit=7, Duration=100,
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccCallReportDigits:
(callID=0x4D5A, digit_event=0x0, enable=FALSE, consume=FALSE)
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2D737304, callID=0x4D5A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=551, Params=0x323A0D7C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccCheckClipClir:
Destination Pattern=8..., Called Number=8007, Digit Strip=FALSE
Called Number=8007(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Huynh Trong Nhat Minh
Account Number=, Final Destination Flag=FALSE,
Guid=FC2E5797-5DDE-11E3-A4EE-8341BD754293, Outgoing Dial-peer=551
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=7011
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=8007
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3142B0E0, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=7011,(Calling Name=Huynh Trong Nhat Minh)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8007(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=551, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Dec 6 18:56:45.410: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 6 18:56:45.410: :cc_get_feature_vsa malloc success
Dec 6 18:56:45.410: cc_get_feature_vsa count is 3
Dec 6 18:56:45.410: :FEATURE_VSA attributes are: feature_name:0,feature_time:842530536,feature_id:15990
Dec 6 18:56:45.410: //19803/FC2E5797A4EE/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Dec 6 18:56:45.410: //19803/FC2E5797A4EE/CCAPI/ccCallSetContext:
Context=0x323A0D2C
Dec 6 18:56:45.410: //19802/FC2E5797A4EE/CCAPI/ccSaveDialpeerTag:
Dec 6 18:56:45.414: //19803/FC2E5797A4EE/CCAPI/cc_api_call_proceeding:
Interface=0x3142B0E0, Progress Indication=NULL(0)
Dec 6 18:56:45.418: //19803/FC2E5797A4EE/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8007@172.16.17.15:5068 SIP/2.0
Via: SIP/2.0/UDP 172.16.17.249:5060;branch=z9hG4bK5C367
From: "Huynh Trong Nhat Minh" <sip:7011@172.16.17.249>;tag=D7BA663C-10A1
To: <sip:8007@172.16.17.15>
Date: Fri, 06 Dec 2013 18:56:45 GMT
Call-ID: FCA6950D-5DDE11E3-A4F38341-BD754293@172.16.17.249
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 4230895511-1574834659-2767094593-3178578579
User-Agent: Cisco-SIPGateway/IOS-15.2.2.T
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1386356205
Contact: <sip:7011@172.16.17.249:5060>
Expires: 180
Allow-Events: telephone-event
P-Asserted-Identity: "Huynh Trong Nhat Minh" <sip:7011@172.16.17.249>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 2128 9705 IN IP4 172.16.17.249
s=SIP Call
c=IN IP4 172.16.17.249
t=0 0
m=audio 23416 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Dec 6 18:56:45.914: //19803/FC2E5797A4EE/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x3142B0E0, Call Id=19803
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Dec 6 18:56:45.914: //19802/FC2E5797A4EE/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Dec 6 18:56:45.914: //19803/FC2E5797A4EE/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=19803
Dec 6 18:56:45.914: //19803/FC2E5797A4EE/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Dec 6 18:56:45.914: //19803/FC2E5797A4EE/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x3142B0E0, Tag=0x0, Call Id=19803,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Dec 6 18:56:45.914: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 6 18:56:45.914: :cc_free_feature_vsa freeing 3237FEE0
BMT-HCM-R2911-VoIP#
Dec 6 18:56:45.914: vsacount in free is 2
Dec 6 18:56:45.914: //19802/FC2E5797A4EE/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Dec 6 18:56:45.914: //19802/FC2E5797A4EE/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
BMT-HCM-R2911-VoIP#
Dec 6 18:56:47.206: //19802/FC2E5797A4EE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2D737304, Tag=0x0, Call Id=19802,
Dec 6 18:56:47.206: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 6 18:56:47.206: :cc_free_feature_vsa freeing 3237F1C0
Dec 6 18:56:47.206: vsacount in free is 1
BMT-HCM-R2911-VoIP#
12-06-2013 11:51 AM
Please post "debug ccsip messages".
Based on your debug you are getting "Cause No. 38 - network out of order."
You may want to bind SIP to an interface that the IP address is defined which Lync points to.
Chris
