06-19-2024
01:44 PM
- last edited on
06-19-2024
01:44 PM
by
Gabriela Godoi do Prado
Cheers, I'm trying to update Minimum Ring Volume set it to 10, we have 700 telephones (7911, 8841, 8845) through BAT
Bulk Administration > Phones > Update phones > Query
But it does not display option Minimum Ring Volume (nor Product Specific Configuration Layout)
could you please advise?
Solved! Go to Solution.
06-21-2024 06:20 AM
06-19-2024 10:08 PM
That setting is not possible to modify with the BAT query option. You need to use the export/import BAT option and modify the CSV file in the TAR file to change this.
06-21-2024 06:20 AM
Hello, I was able to use the option successfully.
Best regards,
Luis
06-21-2024 07:08 AM - edited 06-21-2024 07:08 AM
Glad to hear that Luis!
May I ask why you marked your own response as the solution to your question instead of mine?
