Cisco Call Manager Minimum Ring Volume BAT
Translator
Community Manager
Community Manager
Cheers, I'm trying to update Minimum Ring Volume set it to 10, we have 700 telephones (7911, 8841, 8845) through BAT
Bulk Administration > Phones > Update phones > Query
But it does not display option Minimum Ring Volume (nor Product Specific Configuration Layout)
Cisco Unified CM Administration
System version 11.0.1.22900-14
could you please advise?
Translator
Community Manager
Community Manager
Hello, I was able to use the option successfully.
Best regards,
Luis
That setting is not possible to modify with the BAT query option. You need to use the export/import BAT option and modify the CSV file in the TAR file to change this.
Response Signature
Translator
Community Manager
Community Manager
Best regards,
Luis
Glad to hear that Luis!
May I ask why you marked your own response as the solution to your question instead of mine?
Response Signature
