cisco callmanager 5.X Access log issue
eljose_lol
Hi Everybody!
i wish to know how to see and configure the log into CCM 5.1.3,  i know its by RTM, but i cound´t find the info. I need know wich user made some change or tried to log in.
thanks.
Craig Cooper
Hi Eljose,
If Debug level tracing is enabled on Cisco Role-based Security, then you should be able to collect the Access Log through RTMT and collect what you're after.
Kind regards,
Craig
5.x doesn't have role based security logs, that's 7.X and above only. The only chance to get any info is to review the tomcat logs.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime,
Thanks for your input.   Yes, the logs were certainly limited in CUCM 5.x.   Hopefully the Access Logs I provided the link for above, in the Cisco Unified CallManager System Guide, Release 5.1(3), will be sufficient for the customer.
Craig
