Cisco CallManager-Unity-Presence not Start Automatically in UCS c220M2 VM
We Have Cisco Server UCS C220 M2 with Vware Esxi 5.0, and after installation of every vm i need to each of this start automatically when the physical server start.
Acccording to this doc ( http://pubs.vmware.com/vsphere-50/index.jsp#com.vmware.vsphere.vm_admin.doc_50/GUID-6CA3CCF8-71A7-4167-AA5D-86BB67CF060D.html#GUID-6CA3CCF8-71A7-4167-AA5D-86BB67CF060D )
the steps are correct in my configuration, but after restart the physical server the vm still in shutdown state.
Note: We are running CUCM 9.1 CUC 9.1 and CUP 9.1
Any can help me.
Thanks.
8 Replies 8
ahmed_maher
Hi Christian,
I face the same issue, did you be able to solve it?
Hi Ahmed,
Not the problem even continuos, today i will try to apply vmware upgrades and post if this works or not.
I have not had any issues with it, can you post a screen shot of you startup/shutdown configuration?
Chris
Hi Chris,
What exact version of Vmware you have ?
I Have VMware ESXi 5.0.0 build-623860 and seeing the picture of Ahmed, he also have the same version.
Hi Community,
I solved the issue, it's necessary to install pacth "ESXi500-201207001" to Vmware ESXi.
Look this
http://communities.vmware.com/thread/403010?start=0&tstart=0
and to apply the patch look:
http://www.youtube.com/watch?v=eycokxFEid8
Here you can find the patch:
http://www.vmware.com/patchmgr/findPatch.portal
Good Luck !!
Thansks Christian,
i did the update also and it worked, do you know if Esxi 5.1 is supported ?
thanks
ESXi 5.1 is now supported on most but not all apps, see the link for the complete list:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
HTH, please rate all useful posts!
Chris
