Cisco CME IP Phone Time issue
JackBurr28174
Hello Everyone,
I am currently having an issue with regards to changing the time on our CME.
I do the following, get into the voice register global, set the timezone to 17, then 'create profile'. then i get the following errors.
%Error deleting flash:/its/jabber-config.xml (No such file or directory)
%Error deleting flash:/its/SEPAAAABBBBCCCC.cnf.xml (No such file or directory)
Any ideas how to get around this?
Rory
For time issue use below
timezone 17
time-format 24
date-format D/M/Y
Then issue create profile.
you can ignore the below
Response Signature
Thanks for your reply, i tried your solution and
Now i am getting this error
(config-register-global)#restart
No contact info available for pool 3.
No contact info available for pool 5.
No contact info available for pool 24.
No contact info available for pool 27
Still no change to the times on the IP phones, what am i missing here..haha
Can you post your voice register global config, one of the pools mentioned above, and the NTP/time config on the host router? You are right that there is something missing, but it's hard to tell without more information.
Maren
