Cisco CME time zone. How to remove daylight time
netone.cisco
Hello all,
Our company has CME v7.1 running on a 3845. Our phones are mostly 7906 and 7911. I live in Angola, a country with GMT+1 time. We dont have Daylight Savings Time and our time is constant the whole year. Time is displayed correctly except it changes along the year.
The list of time under telephony service only have +60(min) time zone with Daylight time (check below)
Is there anyway to remove the DST just like "clock set" on exec mode?
Thanks very much
    rw-ld-sede-01(config-telephony)#time-zone ?
      <1-53>  select timezone name used by IP phones (offset in minutes)
    1 Dateline Standard Time -720
    18 SA Eastern Standard Time -180
    19 Mid-Atlantic Standard/Daylight Time -120
    20 Azores Standard/Daylight Time -60
    21 GMT Standard/Daylight Time +0
    22 Greenwich Standard Time +0
    23 W. Europe Standard/Daylight Time +60
    24 GTB Standard/Daylight Time +60
    25 Egypt Standard/Daylight Time +60
    26 E. Europe Standard/Daylight Time +60
    27 Romance Standard/Daylight Time +120
paolo bevilacqua
If there is no correct TZ, you will have to manually change time twice a year.
6 Replies 6
paolo bevilacqua
Paolo,
Thanks for your time.
Really? I have seen information talking about "locale" installation for different languages. Is there no way to install new time-zones?
As mentioned before:
There is NO way.
Please remember to rate useful posts clicking on the stars below.
Thanks Paolo,
I'll just have to keep changin then. Anywhere I can make feature requests to CISCO?
netone.cisco wrote:
Thanks Paolo,
You could, but it's mostly wasted time.
Thanks for the nice rating, and good luck!
Quick question from a newbie : I'm facing the same issue, so how do you manually change the time on CME ?
