Cisco CUBE SIP trunk call out fail
Kosi227
Hi all,
one of our customer facing a issues when trying use the SIP trunk to call out
CUCM10.5 ->SIP Trunk-->CUBE-->SIP-->TELCO
customer can receive the call from the telco via this sip ,and works fine. But when customer trying to make a call out will get the fast busy tone. i try to use debug voip ccapi inout and found the disconnect cause as below:
Disconnect Cause (CC) : 41
Disconnect Cause (SIP) : 500
the full log is attached for reference , please help.
thanks !
Accept what was and what is, and you’ll have more positive energy to pursue what will be.
9 Replies 9
vladpetra
Hello simontse227
Can you attach your config of the CUBE for a review?
ok, please find the running config in attached
more information that:
this cube have E1 and SIP trunk connection from provider , we use cor list to control the extension to use which path to call out. extension 38XXX will use SIP , and extension 35XXX will use the E1. and the E1 is working fine with any issues
and more information from customer , they can use the this SIP trunk to make the international call (eg. 0061XXXXXX) , only the local call will fail with fast busy tone...so strange...
thanks !
gsikarwar
Check If "shutdown" command is there under voice service voip ?
yes, we check it already, all dial peer and voip service is active now
Dennis Mink
can you share the debug csip message output of a failing call.
Please remember to rate useful posts, by clicking on the stars below.
here you are, i just capture one of fail call message . thanks !
R0g22
You are getting a 500 from ITSP -
007227: May 24 10:17:55: //61178/0051DDA94C01/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/UDP 191.1.5.105:5060;branch=z9hG4bK8C9B1F1F
Record-Route: <sip:191.0.16.181:5060;transport=udp;lr>
Call-ID: 80D3BA22-5E2F11E8-AAE5CAAC-C4684751@191.1.5.105
From: "Crystal Zhou"<sip:50298107@191.1.5.105>;tag=3FEABB88-106F
To: <sip:62793502@191.0.16.181>;tag=sbc0406127.0.0.1alUtKGp-02092+1+d89c01a0+74ec8562
CSeq: 101 INVITE
Server: Alcatel-Lucent 5060 MGC-8 9.8.0.2.0.29
Supported: replaces,path,100rel,timer
Contact: <sip:62793502@191.0.16.181:5060>
Expires: 180
Content-Length: 0
You can contact them and see what is going on.
I agree with Nipun, you'll need to contact your service provider.
You may need to change something on your end but they'll have to tell you what they don't like about the INVITE.  It can be incorrect source IP, calling number, or they require EO instead of DO.  Or, it might be something completely on their end.
thanks all, will try to contact the service provider to check the issues !
