10-30-2013 02:06 PM - edited 03-16-2019 08:09 PM
Running into an issue sending an inbound SIP PSTN call from the CUBE to the Call Manager, have setup per provider docs but the call is failing with a SIP/2.0 404 Not Found, not sure if it cannot find the SIP trunk to Call Manager or if its a config issue.... See config and results below:
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
boot-start-marker
boot system flash c3900e-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
logging buffered 16777216
aaa new-model
aaa authentication login default group tacacs+ local-case enable none
aaa authentication login CONSOLE none
aaa authorization console
aaa authorization exec default group tacacs+ local
aaa authorization exec CONSOLE none
aaa authorization commands 15 default group tacacs+ local
aaa authorization commands 15 CONSOLE none
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
clock timezone CST -6 0
clock summer-time CST recurring
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip domain name ad.twtelecom.com
ip host srvuccm2pub1.ad.twtelecom.com 10.47.61.10
ip host srvuccm2sub1.ad.twtelecom.com 10.47.61.11
ip host srvuccm2sub2.ad.twtelecom.com 10.47.61.12
ip host srvuccm2sub3.ad.twtelecom.com 10.1.61.14
ip host srvuccm2sub4.ad.twtelecom.com 10.1.61.15
ip host srvucsvc1.ad.twtelecom.com 10.1.62.10
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub1.ad.twtelecom.com
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub2.ad.twtelecom.com
ip host _sip._udp.cmg-dlfw.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub3.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub4.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub3.ad.twtelecom.com
ip host _sip._udp.cmg-dnvr.srvuccm2.uc.twtelecom.com srv 10 50 5060 srvuccm2sub2.ad.twtelecom.com
ip name-server 10.1.33.50
ip name-server 10.47.31.10
voice-card 0
no voice hunt unassigned-number
no voice hunt invalid-number
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.47.61.10
ipv4 10.47.61.11
ipv4 10.47.61.12
ipv4 10.1.61.14
ipv4 10.1.61.15
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
early-offer forced
midcall-signaling passthru
sip-profiles 101
voice class sip-profiles 101
request INVITE sip-header Allow-Header remove
response 200 sip-header Allow-Header remove
response 180 sip-header Allow-Header remove
response 183 sip-header Allow-Header remove
voice translation-rule 1000
rule 1 /469484\(5...\)$/ /85\1/
voice translation-profile InboundPSTNCalls
translate called 1000
license udi pid C3900-SPE250/K9 sn FOC17307TDF
hw-module pvdm 0/0
redundancy
ip ssh version 2
interface Loopback192
ip address 10.47.69.15 255.255.255.255
interface GigabitEthernet0/0
description port 1
ip address 10.47.69.2 255.255.255.252
ip pim sparse-mode
ip ospf network point-to-point
duplex auto
speed auto
interface GigabitEthernet0/1
description port 2
ip address 10.47.69.6 255.255.255.252
ip pim sparse-mode
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
description FVX Interface
ip address 10.0.29.194 255.255.255.252
duplex full
speed 1000
router ospf 4323
auto-cost reference-bandwidth 20000
area 10.47.69.0 stub
network 10.47.69.0 0.0.0.255 area 10.47.69.0
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.47.69.0
logging trap debugging
logging origin-id hostname
logging facility local0
logging source-interface GigabitEthernet0/0
logging 10.1.62.20
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
dspfarm profile 20 mtp
description MTP-dlfwdc3vg01ES
codec g711ulaw
codec pass-through
maximum sessions software 10000
associate application SCCP
dial-peer voice 104 voip
description PBX calls to extension
huntstop
destination-pattern 8.....
session target dns:cmg-dlfw.srvuccm2.uc.twtelecom.com
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs3 signaling
dial-peer voice 103 voip
description Inbound PSTN calls
translation-profile incoming InboundPSTNCalls
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 101 voip
description PSTN Long Distance
huntstop
destination-pattern 1..........
session target ipv4:10.0.29.193
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 102 voip
description PSTN International
huntstop
destination-pattern 011.T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 100 voip
description PSTN local number
huntstop
destination-pattern ..........
dtmf-relay rtp-nte
codec g711ulaw
gatekeeper
shutdown
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4694845402@10.0.29.194:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.29.193:5060;branch=z9hG4bK-d8754z-FRBRTXJGEB0010004e9fb863c2142-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:6366257074@10.0.29.193:5060>
To: <sip:4694845402@10.0.29.194:5060>
From: "TW TELECOM INC "<sip:6366257074@10.0.29.193:5060>;tag=FRBRTXJGEB0010004e9fb863c2143
Call-ID: 66dda242.c21d000a.527171c4.f1c87
CSeq: 1 INVITE
Session-Expires: 1800;refresher=uac
Min-SE: 1800
Content-Type: application/sdp
Supported: timer
Remote-Party-ID: "TW TELECOM INC "<sip:6366257074@10.0.29.193:5060>;privacy=off
Content-Length: 185
v=0
o=fvx 763 1 IN IP4 tekvizion.com
s=FortisWave
c=IN IP4 10.0.29.193
t=0 0
m=audio 39412 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=4694845402, Called Number=4694845402, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=4694845402
Result=Success(0) after DP_MATCH_DEST
Oct 30 2013 15:53:24.995 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=4694845402, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=100
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=6366257074, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=100
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpAssociateIncomingPeerCore:
Calling Number=6366257074, Called Number=4694845402, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=103
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchSafModulePlugin:
Oct 30 2013 15:53:24.997 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=4694845402, Peer Info Type=DIALPEER_INFO_SPEECH
dialstring=4694845402, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
Oct 30 2013 15:53:24.997 CST: //83/2771296280A0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 30 Oct 2013 20:53:24 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchPeersCore:
Calling Number=, Called Number=855402, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=855402
dialstring=855402, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.997 CST: //-1/2771296280A0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=104
Result=SUCCESS(0)
Calling Number=855402, Called Number=855402, Peer Info Type=DIALPEER_INFO_SPEECH
Result=SUCCESS(0)
Calling Number=855402, Called Number=, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=104
Result=SUCCESS(0)
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchPeersCore:
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchSafModulePlugin:
dialstring=855402, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Oct 30 2013 15:53:24.999 CST: //-1/2771296280A0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Oct 30 2013 15:53:24.999 CST: //83/2771296280A0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:4694845402@10.0.29.194:5060>;tag=392ED2-1D58
CSeq: 1 INVITE
Reason: Q.850;cause=3
Content-Length: 0
Oct 30 2013 15:53:24.999 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
dlfw-dc3-vg01ES#ACK sip:4694845402@10.0.29.194:5060 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Solved! Go to Solution.
09-15-2014 04:45 AM
Hi Deji,
Thanks for the response. I however still have this issue. I didnt come back because the project was suspended, but I've been instructed to cut over to this circuit and this issue is still pressing.
I contacted the provider, quoting your statement above but they maintained that their end is good since it issue does not appear on clients network.
The only difference between the other clients and my network, is they that they use plain SIP PBX while I use CUCM with Voice Gateway.
Any suggestion will be highly appreciated.
09-15-2014 06:03 AM
I am not sure there is any other thing to say other than what I have already said. Your provider need to send either 183 session progress or 180 ringing, but not both. Go back to them and tell their end is not okay. Show them the logs.
09-15-2014 07:37 AM
I completely agree with Deji , ITSP should not send both 183 and 180 on a single call.
Just to try a workaround can you do these changes and let me know the behavior.
1. Enable 100rel on outbound dial-peer towards CUCM.
dial-peer voice XXX voip
voice-class sip rel1xx require 100rel
2. Go to SIP profile of CUCM sip trunk and enable 100rel.
SIP Rel1XX Options
Send PRACK if 1XX contains SDP
And do not disable early media from sip profile and also from CUBE while testing with these changes.
Let me know.
10-03-2014 05:31 AM
Thanks so much Deji and Manish. Following your lead, i found this link on Cisco's site
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116009-ip-phone-fall-tfn-product-tech-note-00.html.
I only implemented you suggestion on the SIP profile of the CUCM and voila.....I can hear the ringback message.
10-03-2014 12:01 PM
Elemzy,
I am glad we could help. You didn't rate any of our post though. Those stars are our bread and butter here..so kindly light them up :)
10-03-2014 12:00 PM
Manish (+5)
I am curious to know why you suggested using PRACK and how it resolved this issue
10-04-2014 03:44 AM
PRACK was exchanged between ITSP and CUBE but not between CUBE and CUCM , so my sole purpose to enable 100rel in that call leg is to extend media flow till call manager which i think was remain terminated till CUBE's ITSP interface by the absence of PRACK in CUBE to CUCM call leg.
Something which can be verified by enabling packet capture at CUBE interface and looking at the media packets.
I would love to see if ITSP still sends 183 and 180 on a single call.
