Can any body suggest me how Jabber(Windows,IPhone,Android) works from the outside corporate network through Collaboration edge....Should i need to purchase any additional licenses?
Hi All,We have a cluster of 3 call managers. We are planning to change the hardware of the Publisher from MCS 7825 I4 to VM. Hence i request your guidance to do the same which includes Licensing part as well. Main confusion part is Licensing for me.O...
Hi Folks, Due to a technical oversight, we ordered 10.5 software via PUT for an upgrade from 6.1.5 using PCD however, we can't use 10.5 as it isn't supported by third party application but 10.0 is. Question is, as I have 10.5 media, could I upgrade ...
Hey guys, I would like to backup my CUCM 10.5 using SSH pre-shared key. Is it possible?
Hi guysI have a call flow as per the below for a SIP PSTN call inbound to my CUCM cluster via CUBE.ITSIP --> CUBE --> CUCMI am getting a wierd signalling delay 8-10 sec before CUBE sends on the invite to the CUCM. the experience for the external call...
We have Cisco Call Manager 7.1 ,Cisco Voice Gateway Router 2821.Now we are wanting to integrate our existing Analog EPBEX in which 300 Pcs analog phone are running to CUCM.Now the PSTN line connected with EPBEX.What will be the best possible cheapest...
For a small company how do I know when it is time to consider upgrading my phones to IP phones?
I have a 4 year old 7975 phone that is not under a Cisco support contract. When the phone is plugged in to either poe or ac power adapter the only thing that happens is the speaker light will turn on and stay on. When I try the factory reset by hold...
Hello,Last time I was troubleshooting for soft phone call failure issue, where it gets a busy after a ring.Call FlowIP Communicator --> CUCM 9.1 --> SIP Trunk (early offer) --> SME 9.1 --> MGCP GW --> PBXIn the CCM traces I see soft phone was looking...
SEP<MAC Address>.cnf.xml file ifs not creating after registering manually by using mac address, Still my phone is loading only default config file :( can some help me on this ?
Hi EveryoneI am using VIC 2 FXO card and Video IP Phone.I want to configure fxo port like if any call comes over fxo port and land on video ip phone (voice only).ThanksManinder
This is for CUCM 8.6 with 7945's with SIP image SIP45.9-3-1SR1-1S.When internal call is placed and the called party goes off-hook then sometimes one or the other phone will spontaneously initiate a new call which puts the original call on hold. Add...
hello, i order a cisco 2911 router with smart net and S29UK9-15204M, FL-CME, L-CME-SRST-5 and 21 ip phone 7821 i want to ask are the cme files come with a router or i must buy it. thanks a lot
Hai I need help to design one analog voice gateway for call manager which has at present 40 analog pstn lines. I need to use this for calls. Be6k is going to implement. There will be around 200 analog phones too. Please advice which gateway I can u...
The hotline is like emergency phone with no keypad, and shall be connected to an identical phone automatically when it's placed in an off-hook condition?seems very easy but i donot know where to configure this.Thanks!
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
5 | |
3 | |
2 | |
1 | |
1 |
