Cisco CUCM Forwarding internal to external cell
bnuxoll
User wants phone forwarded after 3 rings to go to an external phone number.
Using cisco cucm - System version: 12.5.1.15900-66
How can i setup a sort of CPG to forward to an external cellphone?
Thank you.
On the DN Configuration Page configure Call Forward No Answer to target the cellphone number and configure the line with a CSS that has access to a PSTN route pattern matching the number. (So, if the PSTN route pattern requires a '9' add the 9 to the forwarding number field). Be sure to also uncheck the Voicemail box.
Maren
Maren
