Blocked inbound caller id calls not routing
jmarberg
We are having an issue where if a caller blocks their caller ID the inbound call is not routed.  I have tested it myself by using *67 and dialing into my desk.  I get a few seconds of silence then the call drops.   The calling party name is anonymous and the calling number shows N/A. I get the end result of unallocated or unassigned number. The call hits CUCM as it is logged in CDR.  So I'm at a routing issue but i don't know what. I can place a call again without the *67 and the call routes as desired. What stops the call based on the callers number from routing?
Thank you
Here is a snippet of the q931 debug:
364557: Oct 30 10:37:41.239: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x2D22
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A1110201190201008209416E6F6E796D6F7573
Protocol Profile = Networking Extensions
0xA1110201190201008209416E6F6E796D6F7573
Component = Invoke component
Invoke Id = 25
Operation = CallingName
Name presentation restricted
Name = Anonymous
Display i = 'Anonymous'
Calling Party Number i = 0x00A0, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '84563'
364558: Oct 30 10:37:41.240: ISDN Se0/1/0:23 Q931: Received SETUP callref = 0xAD22 callID = 0x7500 switch = primary-ni interface = User
364559: Oct 30 10:37:41.244: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xAD22
364560: Oct 30 10:37:41.406: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0xAD22
Cause i = 0x8081 - Unallocated/unassigned number
Then you need to follow this post for how to allow calls with no ANI to be processed. Blocking Calls Based on Calling Party ID
Response Signature
5 Replies 5
Do you have a setup for inbound calls from PSTN to route based on calling number?
Response Signature
jmarberg
We do have some numbers setup to block them from inbound calling but thats all i know of.
Response Signature
We had all of those steps in place, the script was the final fix.  Once that was applied the calls with blocked caller id started coming through.
Thank you!
Look for the "Reject Anonymous Calls" checkbox on the DN configuration page.
Is that ISDN circuit interacting with CUCM using MGCP or a SIP Trunk? If it is a SIP Trunk, also check the "Anonymous Call Block" setting on the SIP Profile. I can't remember if there is a similar setting on an MGCP gateway configuration page, but there could be.
Maren
