02-24-2022 04:11 AM
Hello Cisco team,
Am planning a Cisco CUCM and ISR 4331 gateway Configuration. Anybody done h323 gateway config .Please share example of Configuration example if possible.
CUCM>>h323>>gateway
what are the commands in ISR router.
And in case of FXO what call i need to configure for inboud and outboud calls.
Please share dial Peer.
Solved! Go to Solution.
02-25-2022 02:59 AM
02-24-2022 01:35 PM
There are plenty of configuration documentation available on cisco.com. Advise you to read this or if you do not want to collect the needed knowledge yourself to reach out to a reputable system integrator with a specialisation in Unified Communication.
The community is not here to provide you with a complete configuration without any effort on your part.
02-25-2022 02:59 AM
