07-17-2013 09:18 AM - edited 03-16-2019 06:24 PM
I wonder if it is possible to configure the Cisco Agent Desktop to set the status of the user to Ready when you open the software.
I hope this is possible in PhoneDev.cfg file.
I would also like to know if it is possible to add the password in the configuration.
J'aimerais savoir si c'est possible de configurer le Cisco Desktop Agent pour que le status de l'utilisateur soit à Prêt dès l'ouverture du logiciel.
La configuration à apporter est probablement dans le fichier PhoneDev.cfg.
J'aimerais également savoir si c'est possible de d'ajouter le mot de passe dans la configuration.
Exemple...
[PhoneDevice]
Appearance0=11111
[AgentID]
AgentID=AGENT2
AgentPassword=abc123
[AgentMobilePhone]
RemoteAgent=0
Number=
AgentWorkMode=0
AgentReady=1
Merci de votre aide.
Luc
Solved! Go to Solution.
07-30-2013 06:53 AM
No. All non-defualt CAD behavior is designed to be configured in CDA.
Please remember to rate helpful responses and identify helpful or correct answers.
07-17-2013 09:38 AM
Have you tried creating a workflow to set the agent state to Ready if during the business hours of your contact center?
-Mark Turpin
07-17-2013 09:51 AM
Im not sure to understand your question.
I would like to set the agent state to Ready when a user start Desktop Agent, default is Not Ready.
07-26-2013 09:40 AM
Mark is on the right track. You can create an Agent Management Workflow based on the Startup event which has an Agent State action changing the person to Ready. Explained in the CDA guide, page 92:
07-30-2013 06:37 AM
Is it possible without creating workflow for agent in CDA ?
Is it possible to do that localy by changing client's cfg files, like PhoneDev.cfg ?
Thank you
07-30-2013 06:53 AM
