Cisco Expressway-E X8.8 disable TLS1.0 and enable TLS1.2
Lee Win Neng
Hi all,
I would like seek for some advice on the Cisco Expressway-E with version X8.8 to disable TLS1.0 and enable TLS1.2 for security reason. May I know that does the Cisco Expressway-E X8.8 was able to support TLS1.2 and how to check the current running TLS version via CLI or GUI?
It is because I found that the Cisco documentation was mentioned that only version X8.10 and above was able to check the minimum supported/increase the TLS1.2 for each service on the Maintenance > Security > Ciphers in the GUI with the reference links below.
Kindly advice and much appreciate for help.
Links = https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/TLS/TLS-1-2-Configuration-Overview-Guide.html
0 Replies 0
