Cisco IP Communicator Changing MAC adrress
most_diaa
Hello all,
I have problem with Cisco IP Communicator 8.6.3.0 I changed my laptop and I changed the mac address on  Communicator but it didn't work
and I got message on the display "Configuring IP"
Please support
2 Accepted Solutions
yahsiel2004
Level 7
Level 7
1 - If you changed the IPC MAC address, make sure that the VoIP administrator changes this MAC address in Call Manager. Both sides need to be the same.
2 - If the IPC is showing "Configuring IP", that means that IPC is unable to obtain an IP address from the DHCP server. Verify that your laptop can obtain an address, from the DHCP server.
Yosh
HTH Regards, Yosh
Chintan Gajjar
Level 8
Level 8
please try clearing ip comm config,
go to settings press **# on the screen and press erase. also check the same mac is added for the phone in CUCM.
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
Chintan Gajjar
Level 8
Level 8
Sir i have one cisco Ip Phone issue . could i change the Mac address then the whole configuration taking by the New Ip Phone . Only mac address i can change or need some more configuration to change.
