Cisco IP Phone 7811 unprovisioned
Ahmed habib
Level 3
Level 3
I added the 7811 IP Phone to CME 11.5 and it took an IP but still say unprovisioned
Here is the configuration
R0g22
Add the following -
voice register pool 1
num 1 dn 1
voice register global
create profile
7 Replies 7
R0g22
Add the following -
num 1 dn 1
create profile
OK, The phone become registered but these errors are showed in debug
What is the meaning ?
cisco#debug ccsip err
cisco#debug ccsip error
SIP Call error tracing is enabled
cisco#
*Mar 6 07:37:27.987: //-1/0E0711568035/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
*Mar 6 07:37:28.011: //-1/0E0ABCE48036/SIP/Error/sipSPIFlushDeferredQueue:
*Mar 6 07:37:28.151: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table:
No entry found in sipCallID Table
*Mar 6 07:37:28.151: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
ReqLine IP addr does not match with host IP addr
*Mar 6 07:37:28.155: VOICE REGISTER POOL-1 has registered. Name:SEP00279024A9E7 IP:192.168.70.2 DeviceType:Phone
*Mar 6 07:37:28.155: %SIPPHONE-6-REGISTER: VOICE REGISTER POOL-1 has registered. Name:SEP00279024A9E7 IP:192.168.70.2 DeviceType:Phone
*Mar 6 07:37:28.155: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_locate_in_pattern_table:
***No entry found in Destination pattern Table
*Mar 6 07:37:28.155: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
*Mar 6 07:37:29.135: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateSubscribeDialogSCB:
Could not find scb for response
*Mar 6 07:38:00.159: //1/0E10D7A58037/SIP/Error/sipSPIFlushDeferredQueue:
You can ignore those. Not everything you see in the logs is relevant. It would be difficult to explain every line in that log, here at least.
I had to replace 7911 with 7811 series recenlty.
MAC address has been changed to new one and all configuration seems to be ok but phone stays unprovisioned.
I have call manager configured on old 3845-K9 - It's been done many years ago.I've found config xml's for 79 series but nothing for 78...
Could You suggest anything?
Many thanks,
fisher
@fisher_radionavYou hav to check IF CME Version support 7811 Type or not first
You can't configure 78xx phones on 38xx CMEs. 38xx can't run the required
IOS
**** please remember to rate useful posts
Thank You kindly for quick response and support!
fisher
