le 07-01-2022 10:59 AM
Greetings,
Currently working out with Cisco IP Phone 8851 and 8832 however got stuck with this prompt message. Is there someone here who can help us to go through?
le 07-01-2022 11:44 AM
The phone doesn't have a valid TFTP (or can't reach it) or configuration file from CUCM/CME in order to register, configure either one and you can move forward.
FYI, this has been asked many, many times before, a quick search would have provided the answer.
07-04-2022 12:22 AM - modifié 07-04-2022 12:30 AM
Hi Sir @Jaime Valencia,
What if the plan is not to use a CUCM/CME but will integrate into other that uses SIP protocol, will that be possible? Is the phone still be able to use or am I going to upgrade the firmware for it to be integrated?
le 07-04-2022 03:52 AM
If you have phones with MPP firmware yes. With Enterprise firmware, possible but not recommended as it is a PITA to setup.
le 07-04-2022 04:39 AM
What is PITA?
le 07-04-2022 05:03 AM
Have you ever heard of the concept of search engines? I'm quite sure that use of for example Google and searching for PITA would give you the result that is means Pain In The Ass.
07-04-2022 06:31 AM - modifié 07-04-2022 06:34 AM
@Roger Kallberg, ahahahahaha, I thought the term is something related to Cisco or any other network related concepts, I'm searching for it but can't find an appropriate match. Anyway, thanks so much for your insights, it is greatly appreciated.
le 07-06-2022 12:15 PM
In our case, as per research, I've found out that it can't be possible to upgrade our devices into MPP firmware due to:
Sir @Roger Kallberg and Sir @Jaime Valencia, I just have one follow up question, do you know if what features of CP-8832NR might not be supported after the migration?
le 07-06-2022 12:54 PM
Sorry, but no. I don’t have any experience with MPP software. There are a few others in the community that has experience in this area, hopefully you’ll get help from them on this.
le 07-06-2022 01:21 PM
Sir @Roger Kallberg thank you so much, I appreciate your help and prompt response.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
