11-15-2018 10:16 AM - edited 03-17-2019 01:43 PM
I've noticed that firmware 11.2.1 (I haven't tested for older versions) violates SIP specifications in an embarrassing way when sending a re-SUBSCRIBE within an existing dialog. More specifically, the phone (a 8851 in this case) doesn't use the previously received URI from the Contact header. Instead, it re-uses the R-URI from the initial SUBSCRIBE.
Please find below the cadence of SIP messages demonstrating the problem:
SUBSCRIBE sip:402@my-sip-proxy.net SIP/2.0 Via: SIP/2.0/UDP 2.2.2.2:5064;branch=z9hG4bK-e33ba6a1 From: "johntest-405" <sip:johntest-405@my-sip-proxy.net>;tag=c7976ef9660b6c8c To: <sip:402@my-sip-proxy.net> Call-ID: 14d1519-a9d4fd4d@172.17.173.14 CSeq: 60735 SUBSCRIBE Max-Forwards: 70 Proxy-Authorization: Digest username="johntest-405",realm="my-sip-proxy.net",nonce="W+21WFvttCwi3gqyVA9svGyun5Faqj6X",uri="sip:402@modcom- c",algorithm=MD5,response="aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa" Contact: "johntest-405" <sip:johntest-405@2.2.2.2:5064> Accept: application/dialog-info+xml Expires: 120 Event: dialog User-Agent: Cisco-CP-8851-3PCC/11.2.1 Content-Length: 0 SIP/2.0 200 OK From: <sip:johntest-405@my-sip-proxy.net>;tag=c7976ef9660b6c8c To: <sip:402@my-sip-proxy.net>;tag=as74e10ebb Call-ID: 14d1519-a9d4fd4d@172.17.173.14 CSeq: 60735 SUBSCRIBE Server: modCOM v2 SIP Server Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE Supported: replaces, timer Expires: 120 Content-Length: 0 Via: SIP/2.0/UDP 2.2.2.2:5064;rport=5064;branch=z9hG4bK-e33ba6a1 Contact: <sip:atpsh-5bed8859-3719-2@3.3.3.3>
The URI from the response's Contact: header should be used for all subsequent
in-dialog requests from the phone. Instead: SUBSCRIBE sip:402@my-sip-proxy.net SIP/2.0 Via: SIP/2.0/UDP 2.2.2.2:5064;branch=z9hG4bK-81b84571 From: "johntest-405" <sip:johntest-405@my-sip-proxy.net>;tag=c7976ef9660b6c8c To: <sip:402@my-sip-proxy.net>;tag=as74e10ebb Call-ID: 14d1519-a9d4fd4d@172.17.173.14 CSeq: 60736 SUBSCRIBE Max-Forwards: 70 Proxy-Authorization: Digest username="johntest-405",realm="my-sip-proxy.net",nonce="W+21WFvttCwi3gqyVA9svGyun5Faqj6X",uri="sip:402@modcom- c",algorithm=MD5,response="aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa" Contact: "johntest-405" <sip:johntest-405@2.2.2.2:5064> Accept: application/dialog-info+xml Expires: 120 Event: dialog User-Agent: Cisco-CP-8851-3PCC/11.2.1 Content-Length: 0
Public IPs, hostnames and challenge responses have been edited for privacy/seccurity reasons.
BR,
George
11-16-2018 10:22 AM - edited 11-16-2018 10:24 AM
Can someone from Cisco confirm if/when this will be registered as a bug report for 3PCC firmware on the 8800-Series of IP Phones?
Thanks.
11-17-2018 11:08 AM
11-20-2018 06:44 AM
I have no expectations for a fix. However, it's a little frustrating that there's no formal procedure to report serious bugs, such as this one involving RFC violations, when one does not have an active TAC subscription. Personally, I would be satisfied if a bug report were created which I then would be able to watch for updates.
12-04-2018 11:13 AM
Hello.
Where were these packets captured?
Please attach a PRT or a Packet capture taken from the phone web page (http://[Phone IP]/admin/advanced).
Info->Debug Info->Start Packet Capture (Start after phone bootup and stop after the issue is seen)
Info->Debug Info->Generate PRT (Generate after issue is seen. Set Debug level to DEBUG[Voice->System->Debug Level])
Thanks.
