Cisco IP Phone 9971 Video Call
alshahiry
Hi Support,
Can you guide of how I can confirm a Video call between Cisco IP phones 9971 as I can do only voice calls, kindly advise?
Jaime Valencia
You need to start by mentioning what you use for call control.
Generic answer is you need to enable video, thats pretty much it.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
java
Dear Jaime,
Can you advise where I can enable video call for CP 9971?
Again, you need to mention what you use for call control and version, if you want help
java
Dear Jaime,
What I want is how I can do the video call through CP 9971 as its now by default only doing voice calls even when the Camera is attached to IP phone. Any features. On CUCM or IP phone need to be enabled?
It's has been solved by enabling two features on CP 9971 configuration through CUCM which are:
Cisco Camera = Enabled
Video Capabilities = Enabled
