Cisco ISR G2 SIP Calls Capacity
savio.ibrahim
Dear all,
We're planning for Cisco Voice Gateway configuration with SIP trunk, till now no E1s are used.
I would like to know how can we calculate the number of simulataneous calls that a cisco ISR G2 router (1921. 2921.3945,etc...) can support ?
How much sip simultaneous calls each ISR G2 model can support ?
Is it better to use SIP or we must get into E1 PRI ?
Ayodeji Okanlawon
The Q and A below has the call capacity you are looking for
Table 1. Number of IP-to-IP Calls per Platform
Platform
Maximum Number of Simultaneous Calls (Flow-Through)
Cisco 3945E
2500
Cisco 3925E
2100
Cisco 3945
950
Cisco 3925
800
Cisco 2951
500
Cisco 2921
400
Cisco 2911
200
Cisco 2901
100
Cisco ASR 1004; and Cisco ASR 1006 Router Processor 2 (RP2)
5000; 16000*
Cisco ASR 1002, ASR 1004, and ASR 1006 RP1
1750
Cisco AS5350XM and AS5400XM
600
Cisco 3845
500
Cisco 3825
400
Cisco 2851
225
Cisco 2821
200
Cisco 2811
110
Cisco 2801
55
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/prod_qas09186a00801da69b.html
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
5 Replies 5
Ayodeji Okanlawon
Platform
Cisco 3945E
2500
Cisco 3925E
2100
Cisco 3945
950
Cisco 3925
800
Cisco 2951
500
Cisco 2921
400
Cisco 2911
200
Cisco 2901
100
5000; 16000*
1750
600
Cisco 3845
500
Cisco 3825
400
Cisco 2851
225
Cisco 2821
200
Cisco 2811
110
Cisco 2801
55
Be careful not to make your decision solely based on the maximum concurrent calls. The far lower number is call [setup/teardown] per second. Keep in mind that Mobile Connect will significantly amplify this. Page 15 of the following document shows the details.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks for the very useful answer!
We have 3 PVDM with 256. so how many calls can be handled by the Cisco 3945 and 2921 gateway.
Is it the same 950 calls or more?
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9 with 1782784K/314368K bytes of memory.
8 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
2005920K bytes of ATA System CompactFlash 0 (Read/Write)
NAME: "Cisco Services Performance Engine 250 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 250 for Cisco 3900 ISR"
PID: C3900-SPE250/K9 , VID: V05 , SN:
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 0", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 3", DESCR: "PVDM3 DSP DIMM with 256 Channels"
PID: PVDM3-256 , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 256 Channels"
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 256 Channels"
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V04 , SN:
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
1627684864 bytes available (426049536 bytes used).
It depends on the codecs used and media resources
Use dsp calculator below to find out
https://www.cisco.com/c/en/us/applications/dsp-calc.html
**** remember to rate useful posts
