05-22-2018 02:37 PM - edited 03-17-2019 12:51 PM
I have an ISR 4331. I am replacing a 2901 with CME. I don't understand enough about what has changed. Do I have all the licenses and hardware necessary to control 10 phones on this router? 3 POTS incoming with 10 out. I had a nice GUI interface with the ISM on the 2901, I don't see where or how to configure that. The commands all seem different too. Can anyone point me in the right direction? I promise I have google'd and researched everything I possibly could before turning here. I'm stuck.
TDS_MID_ISR4300#sh license Index 1 Feature: appxk9 Period left: Not Activated Period Used: 0 minute 0 second License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted License Count: Non-Counted License Priority: None Index 2 Feature: uck9 Period left: Life time License Type: Permanent License State: Active, In Use License Count: Non-Counted License Priority: Medium Index 3 Feature: securityk9 Period left: Life time License Type: Permanent License State: Active, In Use License Count: Non-Counted License Priority: Medium Index 4 Feature: ipbasek9 Period left: Life time License Type: Permanent License State: Active, In Use License Count: Non-Counted License Priority: Medium Index 5 Feature: FoundationSuiteK9 Period left: Not Activated Period Used: 0 minute 0 second License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted License Count: Non-Counted License Priority: None Index 6 Feature: AdvUCSuiteK9 Period left: Not Activated Period Used: 0 minute 0 second License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted License Count: Non-Counted License Priority: None Index 7 Feature: cme-srst Period left: 7 weeks 3 days Period Used: 1 week 0 day License Type: EvalRightToUse License State: Active, In Use License Count: 42/0 (In-use/Violation) License Priority: Low Index 8 Feature: hseck9 Index 9 Feature: throughput Period left: Not Activated Period Used: 0 minute 0 second License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted License Count: Non-Counted License Priority: None Index 10 Feature: internal_service
TDS_MID_ISR4300#sh inventory +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ INFO: Please use "show license UDI" to get serial number for licensing. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis" PID: ISR4331/K9 , VID: V04 , SN: NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330" PID: PWR-4330-AC , VID: V02 , SN: NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly" PID: ACS-4330-FANASSY , VID: , SN: NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller" PID: ISR4331/K9 , VID: , SN: NAME: "NIM subslot 0/1", DESCR: "NIM-4FXO Voice Analog Module" PID: NIM-4FXO , VID: V01 , SN: NAME: "PVDM subslot 0/4", DESCR: "PVDM4-32 Voice DSP Module" PID: PVDM4-32 , VID: V02 , SN: NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module" PID: ISR4331-3x1GE , VID: V01 , SN: NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller" PID: ISR4331/K9 , VID: , SN: NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor" PID: ISR4331/K9 , VID: V04 , SN: NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor" PID: ISR4331/K9 , VID: , SN:
Cisco IOS XE Software, Version 16.08.01 Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.8.1, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2018 by Cisco Systems, Inc.
Solved! Go to Solution.
05-22-2018 02:45 PM
05-22-2018 02:45 PM
05-23-2018 08:17 AM
3 DID's the rest will be Extension only.
I had CME on the old one not on the new one yet.
Can you tell me what package I need in the downloads for this router. Is it Cucm or cme? That is a little of where I am confused.
05-23-2018 08:31 AM
05-23-2018 08:34 AM
I didn't see the version 12.1 until I went back and looked again. (Apologize for my lack of attention)
I am going to do some more digging and see if this is the answer I am needing. So far Thank you for the help. It has made a world of difference.
05-24-2018 02:36 PM
The phones work, but is the voicemail separate or does it have a separate configuration?
05-24-2018 02:49 PM
05-24-2018 02:53 PM
Crap.. What hardware / Licensing am I missing? I only need 10 VM's?
05-24-2018 02:58 PM
05-24-2018 03:01 PM
Since it's local and only 10 boxes I take it the NIM would be the easiest and cheapest way to go?
05-24-2018 04:01 PM
05-25-2018 06:21 AM
Thank you sir for your responses. I have learned much!
05-03-2019 09:21 AM
Hi Experts
Since they touch on the issue of CME licenses, I'm about to offer a solution of 15 7821 phones with CME, I remember that with the 2900 series for the CUE (Unity Express) to work, it required the FL-CUE-PORT-2 license, this it's just basic functions of IVR and Call Input in IVR.
I see that in ISR4321 this has changed, I can not find the corresponding license for IVR functions in the 4000 series, someone knows something about it by licensing or similar to FL-CUE-PORT-2 in the 4000 series.
I am considering a UCS module in ISR 4321 for the CUE,
Any response will be well received,
Greetings.
Carlos P.
05-23-2019 01:03 AM
I have ISR4451 with CUCM license, FXS ports.
Can we do configuration for hotline? do we need more other parts from Cisco?
Can you help me?
Attached is our PO
05-23-2019 04:15 PM
What do you want to offer CME?
or you want to use it as a voice gateway and register it to your CUCM as H323, MGCP or SIP
Regards.
Carlos.
