Cisco phone 7945/7962, CME 10.5 and local directory problems
kamil_folga
Hi!
I have CME 10.5. I setting up local directory on the CME, which operates properly for phones 6921, but not for phone 7945/7962. On the 7945 appears local directory in menu, but if I select this option, appears "XML Parse Error [4]" . The same occurs on phones 7962. XML config file for phones 7945/7962 contain:
<directoryURL>http://192.168.17.1:80/localdirectory</directoryURL>
What could be the problem?
Config telephony-service:
telephony-service
 max-ephones 40
 max-dn 80
 ip source-address 192.168.17.1 port 2000 secondary 192.168.18.70
 calling-number initiator
 service dnis overlay
 service dnis dir-lookup
 service dss
 timeouts interdigit 5
 system message BLA
 url directories http://192.168.17.1:80/localdirectory
 cnf-file location flash:
 cnf-file perphone
 user-locale 1 U1 PL
 network-locale U1
 network-locale 1 U1
 load 7915-24 B015-1-0-4-2.SBN
 load 7945 SCCP45.9-4-2-1S
 load 7962 SCCP42.9-3-1SR1-1S
 load 7965 SCCP45.9-4-2-1S
 load 6921 SCCP69xx.9-2-1-0
 time-zone 23
 time-format 24
 date-format dd-mm-yy
 max-conferences 4 gain -6
 call-park system application
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh enable-g711 "flash:music-on-hold.au"
 multicast moh 239.10.16.16 port 2000
 transfer-system full-consult
 transfer-pattern .T
 directory last-name-first
 create cnf-files version-stamp Jan 01 2002 00:00:00
Kamil
13 Replies 13
Hi Kamil.
Can you please attach your full running config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Current configuration : 19195 bytes
! Last configuration change at 13:18:59 GMT Tue May 5 2015
! NVRAM config last updated at 13:20:07 GMT Tue May 5 2015
version 15.4
service password-encryption
hostname C2900_VOICE
boot-start-marker
boot-end-marker
enable password 7 XXX
no aaa new-model
clock timezone GMT 1 0
clock summer-time GMT recurring
network-clock-participate wic 1
ip dhcp excluded-address 192.168.17.1
ip dhcp pool TEL_PULA
 network 192.168.17.0 255.255.255.0
 default-router 192.168.17.1
 option 150 ip 192.168.17.1
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-144236398
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-144236398
 revocation-check none
 rsakeypair TP-self-signed-144236398
crypto pki certificate chain TP-self-signed-144236398
 certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343432 33363339 38301E17 0D313530 34323731 31353234
  315A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3134 34323336
  33393830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  BBBC43E9 77D4C5FD 079F57E0 567BB4F6 74F80295 D89A4B30 1B3958AD E654B735
  FF527475 F1F1114A 7BAAA69D 1C484200 11875378 DFD2BD57 D1CCC3FF 6EB84565
  C4581104 68341C8C F000BE1B 2339685A C847BB80 18BF0175 C392631C 30687D71
  F5371DEE E4691CFA 91C33C6A 9F931A27 B2702F0D D7FC752B 1016077C F12DE7C5
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014FE C7B1D68C 7B945EEB FFB09BAE 435211C0 CF6F4930 1D060355
  1D0E0416 0414FEC7 B1D68C7B 945EEBFF B09BAE43 5211C0CF 6F49300D 06092A86
  4886F70D 01010505 00038181 0041C7BB 99D74128 69A8A2B6 F1C77CD6 E9D3CE86
  C420EC76 EA26628D FD35AE67 B3D5EFDB 0D618808 2F7A6DCC EA1BAF65 704F5701
  601785A4 CC73B893 9D6FA916 6B0E64BF ED6D5FDE 59802B6D DD8DAC3E B86E0C78
  2EDD7865 9CC7E875 1D946D03 F6FCCDAD 4EA24D00 C176F30F B1DB272A D20C0282
  3E2B749F 92EB8646 5FD21B16 54
        quit
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
application
 service aa flash:its-CISCO.2.0.3.0.tcl
  paramspace english index 0
  paramspace english language en
  param operator 4001
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 4999
license udi pid CISCO2921/K9 sn XXXXXXX
license accept end user agreement
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
file privilege 0
username xxx privilege 15 secret 5 XXXXXXXX
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 no cdp enable
interface GigabitEthernet0/0.100
 description phone
 encapsulation dot1Q 100
 ip address 192.168.17.1 255.255.255.0
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 192.168.18.70 255.255.255.0
 duplex auto
 speed auto
interface BRI0/1/0
 no ip address
interface BRI0/1/1
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/GUI
ip route 0.0.0.0 0.0.0.0 192.168.18.1
tftp-server flash:/69xx/SCCP69xx.9-2-1-0.loads alias SCCP69xx.9-2-1-0.loads
tftp-server flash:/69xx/SCCP69xx.9-2-1-0.zz.sgn alias SCCP69xx.9-2-1-0.zz.sgn
tftp-server flash:/69xx/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:/69xx/DSP69xx.0-0-0-8.zz.sgn alias DSP69xx.0-0-0-8.zz.sgn
tftp-server flash:/7915/B015-1-0-4-2.SBN alias B015-1-0-4-2.SBN
tftp-server flash:/pl_PL/rtl-sip.jar alias user_define_1/rtl-sip.jar
tftp-server flash:/pl_PL/7905-dictionary.xml alias user_define_1/7905-dictionary        .xml
tftp-server flash:/pl_PL/7905-font.xml alias user_define_1/7905-font.xml
tftp-server flash:/pl_PL/7905-kate.xml alias user_define_1/7905-kate.xml
tftp-server flash:/pl_PL/7921-dictionary.xml alias user_define_1/7921-dictionary        .xml
tftp-server flash:/pl_PL/7921-font.dat alias user_define_1/7921-font.dat
tftp-server flash:/pl_PL/7921-kate.utf-8.xml alias user_define_1/7921-kate.utf-8        .xml
tftp-server flash:/pl_PL/7921-kate.xml alias user_define_1/7921-kate.xml
tftp-server flash:/pl_PL/7960-dictionary.xml alias user_define_1/7960-dictionary        .xml
tftp-server flash:/pl_PL/7960-dictionary-ext.xml alias user_define_1/7960-dictio        nary-ext.xml
tftp-server flash:/pl_PL/7960-font.xml alias user_define_1/7960-font.xml
tftp-server flash:/pl_PL/7960-kate.xml alias user_define_1/7960-kate.xml
tftp-server flash:/pl_PL/be-sccp.jar alias user_define_1/be-sccp.jar
tftp-server flash:/pl_PL/gp-sccp.jar alias user_define_1/gp-sccp.jar
tftp-server flash:/pl_PL/ipc-sccp.jar alias user_define_1/ipc-sccp.jar
tftp-server flash:/pl_PL/mk-sccp.jar alias user_define_1/mk-sccp.jar
tftp-server flash:/pl_PL/SCCP-dictionary.utf-8.xml alias user_define_1/SCCP-dict        ionary.utf-8.xml
tftp-server flash:/pl_PL/SCCP-dictionary.xml alias user_define_1/SCCP-dictionary        .xml
tftp-server flash:/pl_PL/SCCP-dictionary-ext.xml alias user_define_1/SCCP-dictio        nary-ext.xml
tftp-server flash:/pl_PL/tc-sccp.jar alias user_define_1/tc-sccp.jar
tftp-server flash:/pl_PL/td-sccp.jar alias user_define_1/td-sccp.jar
tftp-server flash:/pl_PL/ld-sip.jar alias user_define_1/ld-sip.jar
tftp-server flash:/pl_PL/rp-sccp.jar alias user_define_1/rp-sccp.jar
tftp-server flash:/pl_PL/rtl-sccp.jar alias user_define_1/rtl-sccp.jar
tftp-server flash:/pl_PL/g4-tones.xml alias user_define_1/g4-tones.xml
tftp-server flash:/pl_PL/be-sip.jar alias user_define_1/be-sip.jar
tftp-server flash:/pl_PL/gd-sip.jar alias user_define_1/gd-sip.jar
tftp-server flash:/pl_PL/gp-sip.jar alias user_define_1/gp-sip.jar
tftp-server flash:/pl_PL/mk-sip.jar alias user_define_1/mk-sip.jar
tftp-server flash:/pl_PL/tc-sip.jar alias user_define_1/tc-sip.jar
tftp-server flash:/pl_PL/td-sip.jar alias user_define_1/td-sip.jar
tftp-server flash:/pl_PL/lk-sip.jar alias user_define_1/lk-sip.jar
tftp-server flash:/pl_PL/cin-sip.jar alias user_define_1/cin-sip.jar
tftp-server flash:/pl_PL/gb-sccp-sip.jar alias user_define_1/gb-sccp-sip.jar
tftp-server flash:/pl_PL/sl-be-sip.jar alias user_define_1/sl-be-sip.jar
tftp-server flash:/pl_PL/sp-sip.jar alias user_define_1/sp-sip.jar
tftp-server flash:/pl_PL/sl-sip.jar alias user_define_1/sl-sip.jar
tftp-server flash:/its/united_states_g3-tones.xml alias United_States/g3-tones.x        ml
tftp-server flash:/7942_7962/cnu42.9-3-1ES8.sbn alias cnu42.9-3-1ES8.sbn
tftp-server flash:/7942_7962/apps42.9-3-1ES8.sbn alias apps42.9-3-1ES8.sbn
tftp-server flash:/7942_7962/cvm42sccp.9-3-1ES8.sbn alias cvm42sccp.9-3-1ES8.sbn
tftp-server flash:/7942_7962/dsp42.9-3-1ES8.sbn alias dsp42.9-3-1ES8.sbn
tftp-server flash:/7942_7962/jar42sccp.9-3-1ES8.sbn alias jar42sccp.9-3-1ES8.sbn
tftp-server flash:/7942_7962/SCCP42.9-3-1SR1-1S.loads alias SCCP42.9-3-1SR1-1S.l        oads
tftp-server flash:/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/7945_7965/SCCP45.9-2-1TH1-13.loads alias SCCP45.9-2-1TH1-13.l        oads
tftp-server flash:/7945_7965/apps45.9-4-2TH1-1.sbn alias apps45.9-4-2TH1-1.sbn
tftp-server flash:/7945_7965/cnu45.9-4-2TH1-1.sbn alias cnu45.9-4-2TH1-1.sbn
tftp-server flash:/7945_7965/cvm45sccp.9-4-2TH1-1.sbn alias cvm45sccp.9-4-2TH1-1        .sbn
tftp-server flash:/7945_7965/dsp45.9-4-2TH1-1.sbn alias dsp45.9-4-2TH1-1.sbn
tftp-server flash:/7945_7965/jar45sccp.9-4-2TH1-1.sbn alias jar45sccp.9-4-2TH1-1        .sbn
tftp-server flash:/7945_7965/SCCP45.9-4-2-1S.loads alias SCCP45.9-4-2-1S.loads
tftp-server flash:/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.x        ml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:music-on-hold.au alias music-on-hold.au
control-plane
voice-port 0/1/0
voice-port 0/1/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 4999 voip
 service aa
 destination-pattern 4999
 session target ipv4:192.168.17.1
 incoming called-number 4999
 dtmf-relay h245-alphanumeric
 codec g711ulaw
 no vad
gatekeeper
 shutdown
telephony-service
 max-ephones 40
 max-dn 80
 service dss
 system message VOICE
 cnf-file perphone
 user-locale 1 U1 PL
 network-locale U1
 network-locale 1 U1
 time-zone 23
 time-format 24
 moh enable-g711 "music-on-hold.au"
 web admin system name XXXXX secret 5 XXXXXX
 transfer-pattern .T
 directory entry 1 34 name XXX XXXX
ephone-template  10
 network-locale 1
 user-locale 1
ephone-dn  1
 number 21
 label XXX
 description 21
 name XXX
ephone-dn  2
 number 22
 label YYY
 description 22
 name YYY
ephone  1
 mac-address F8C2.88A1.XXXX
 ephone-template 10
 type 6921
 button  1:1
ephone  2
 mac-address 00E1.6D15.XXXX
 ephone-template 10
 type 7945
 button  1:2
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7 XXX
 login
 transport input telnet ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server XXX.XX.XXX.XXX
end
Hi Kamil.
Try to remove :80 from the directory url and issue create cnf files under telephony services.
Carlo
Thanks for your reply Carlo.
I have tried without " 80 " but it was also not working.
My only idea is too new load for the phone 7945 (SCCP45.9-4-2-1S), which causes misinterpretation of XML localdirectory. CME 10.5 support load SCCP45.9-2-1S.loads for 7945/7965, but I cannot downgrade phone to this firmware. Phone looping on download term45.defaults.load.
Any idea?
Kamil
Hi Kamil.
Please activate a debug tftp packet while trying to downgrade 7945 and post the output.
Cheers
Carlo
Local directory on phone 7945 with firmware 9-1-1 works OK. But I cant downgrade my phone 7945 to 9-1-1 (I have firmware 9-4-2). Output from the phone:
https://www.youtube.com/watch?v=UQLR50Zkkho
Kamil
Hi Kamil.
A downgrade from 9.4 to 9.1 could have that behaviour.
Start downgrading to 9.4.1 then  to 9.3.2 than try 9.1.
Carlo
Hi Carlo,
9.4.1 and 9.3.2 does not exist for 7945:
https://software.cisco.com/download/release.html?mdfid=281346594&softwareid=282074288&os=&release=9.4(2)SR1&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
I try downgrade to 9.3.1 but have the same error.
show flash
255          0 May 11 2015 14:01:58 +02:00 7945_931
256        674 May 11 2015 14:37:42 +02:00 7945_931/term65.default.loads
257        674 May 11 2015 14:37:32 +02:00 7945_931/term45.default.loads
258        674 May 11 2015 14:37:20 +02:00 7945_931/SCCP45.9-3-1-1S.loads
259    1889607 May 11 2015 14:37:04 +02:00 7945_931/jar45sccp.9-3-1TH2-5.sbn
260     363099 May 11 2015 14:36:40 +02:00 7945_931/dsp45.9-3-1TH2-5.sbn
261    2215327 May 11 2015 14:36:18 +02:00 7945_931/cvm45sccp.9-3-1TH2-5.sbn
262     581056 May 11 2015 14:35:56 +02:00 7945_931/cnu45.9-3-1TH2-5.sbn
263    4665017 May 11 2015 14:35:36 +02:00 7945_931/apps45.9-3-1TH2-5.sbn
tftp bindings:
tftp-server flash:/7945_931/term65.default.loads alias term65.default.loads
tftp-server flash:/7945_931/term45.default.loads alias term45.default.loads
tftp-server flash:/7945_931/SCCP45.9-3-1-1S.loads alias SCCP45.9-3-1-1S.loads
tftp-server flash:/7945_931/jar45sccp.9-3-1TH2-5.sbn alias jar45sccp.9-3-1TH2-5.sbn
tftp-server flash:/7945_931/dsp45.9-3-1TH2-5.sbn alias dsp45.9-3-1TH2-5.sbn
tftp-server flash:/7945_931/cvm45sccp.9-3-1TH2-5.sbn alias cvm45sccp.9-3-1TH2-5.sbn
tftp-server flash:/7945_931/cnu45.9-3-1TH2-5.sbn alias cnu45.9-3-1TH2-5.sbn
tftp-server flash:/7945_931/apps45.9-3-1TH2-5.sbn alias apps45.9-3-1TH2-5.sbn
tftp-events debug:
May 11 12:52:53.222: TFTP: Looking for term45.default.loads
May 11 12:52:53.222: TFTP: Opened flash0:/7945_931/term45.default.loads, fd 4, size 674 for process 60
May 11 12:52:53.226: TFTP: Finished flash0:/7945_931/term45.default.loads, time 00:00:00 for process 60
May 11 12:52:57.850: TFTP: Looking for term45.default.loads
May 11 12:52:57.854: TFTP: Opened flash0:/7945_931/term45.default.loads, fd 4, size 674 for process 60
May 11 12:52:57.854: TFTP: Finished flash0:/7945_931/term45.default.loads, time 00:00:00 for process 60
Kamil
I think the URL Directories command is only needed when using an external directory but you are pointing it back to the CME. Have you tried using the built in directory function? You can try removing the URL Directory command and create CNF to test.
Yes, I tried without URL Directories but this dont work.
I'm having a similar problem with IP phone 7911G in the Local Directory appears the number put to disk when the recorded number on the local directory, the name does not appear in the only number display.
Does anyone have idea what can be?
Problem solved - in EN locale all works fine, in PL locale dont work.
On phone sticker is written "S/W: Must use 9.3(1)SR1 or above" PID VID: CP-7945G V15. CME 10.5 support this phone with firmware 9.2(1).
Kamil
