Minimum Ring Volume
Jason Amick
Quick question on the minimum ring volume setting for various Cisco phones.  I know you can set the minimum ring volume on individual devices and also set it using BAT within call manager.  The piece I am not seeing is this setting listed under the "common phone profile".  In theory I would like the minimum ring volume set on any future phone deployed but it looks like that setting would have to be changed on a per phone bases instead of it being auto set when the common phone profile is chosen on the device side.  Any help would be greatly appreciated.  We are running version 8.6.2.23900-10 of CUCM.  Thanks!!
Manish Gogna
Hi Jason,
I checked the common phone profile settings on cucm 10.0 as well. There is no option to adjust ring volume. So it needs to be done individually or through BAT
Manish
Manish:
Thanks for the reply, I guess that answers my next question as well, if this was going to be addressed in any future release.  Thanks again for your response!!
