cisco phone 7945G called end problem still flashing and alerting
Waisudin Farzam
dear all
i have some cisco 7945 phones when i call one extension to another and it rings after 3 or 4 seconds when i end call still the call is alerting on the incoming phone and i have to forcely end the call its not doning that automaticly can somebody help me what should i do to slove this problem i dont know what is happening to the phones i have some soft phone which installed in my computer and they work fine and i end the call the calls ends at both party but the cisco phones 7945 does not
also when i dial the number it takes 4 to 5 seconds to dial a number.
i dont know why the phones dose not end when i press the end call
this happens when dial the other extenstion and the extensioin dose not pick the phone just flashs the line what i have configured for that phone
please helppppppp meee
regard
Waisudin Farzam
SNE
P E: wfarzam@gmail.com
S E: wais.farzam@gmail.com
S: wais.farzam
Certified Cisco ID: CSCO11404095
CCNA, CCNP, CCNA Sec, and CCIE R&S v4.0 Written Certified
13 Replies 13
Gajanan Pande
Waisudin,
Do you have latest firmware in those phones ? If not, please upgrade them & such issues are usually fixed.
Latest firmware can be downloaded from CCO
GP.
Pls rate helpful posts !!
I have upgraded the phones to the latest sip firmware but the problem was that they failed to connect to Asterisk
Waisudin Farzam
SNE
S: wais.farzam
ronpatel
Level 8
Level 8
Are those phone remotely installed to CUCM.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
They are not registered with cucm they are registered with Asterisk SIP
And all the phones are cisco 7945 except one that is cisco cp7905G
regards
Waisudin Farzam
SNE
S: wais.farzam
Phones are just dummy terminals, so the issue here is not the phones but your call processor.  I suggest you post your question to Asterisk support forums.
HTH,
Chris
Just to add, Cisco Ip phones are not supported and tested to work with third party PBXs. This may be the reason of misbehaving.
Ronak Patel
Then how the cisco 7905g phones works fine with this third party pbx systems
Waisudin Farzam
AGS ICT / DC Manager -- Project IT Specialist
Ministry of Mines,
Afghanistan Geological Survey (AGS)
Sustainable Development of Natural Resources Project
Kabul, Afghanistan
AWCC Cell Phone: 0093 – 700 – 29 60 62
Etisalat Cell Phone: 0093 – 781 – 29 60 62
MTN Cell Phone: 0093 – 777 – 29 60 62
E-Mail Address: wfarzam@gmail.com
E-Mail Address: wfarzam@mom.gov.af
E-Mail Address: wais.farzam@gmail.com
Skype ID: wais.farzam
Waisudin Farzam
SNE
S: wais.farzam
They may or may not work.
Cisco do not test there IP phones against third party PBX. We follow SIP RFC standards when we develop the SIP firmware. But as we have not tested it with third party PBX, we can not say why it is not working for some phones.
Ronak Patel
For example
If you see release notes of Cisco ip phones it clearly states
SIP Firmware Release 9.2(3) is designed and tested to interoperate with Cisco call control, most notably Cisco Unified Communications Manager Release 8.6(1). Although SIP firmware is IETF RFC 3261 compliant, it is not supported by Cisco TAC or Engineering for use with non-Cisco call control systems.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_2_3/english/release/notes/7900_923.html
Ronak patel
Rate helpful posts.
Yes i know but I have installed the 8.5.3 firmware
Waisudin Farzam
SNE
S: wais.farzam
HI
It is for any SIP firmware
release note for 8.5.3 sip firmware
SIP firmware release 8.5(3)SR1 is designed and  tested to interoperate with Cisco call control, most notably Cisco  Unified Communications Manager releases 7.1(5) and 8.0(2). Although SIP  firmware is IETF RFC 3261 compliant, it is not supported by Cisco TAC or  Engineering for use with non-Cisco call control systems.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853SR1.html
Ronak Patel
Hay guys I fixed that up perfectly and works perfect with asterisk system now any body needed help ready to support
Waisudin Farzam
SNE
S: wais.farzam
what did you do exactly? i don't have the problem but just curious on a solution
