06-07-2022 04:41 AM
Hi Dear Friends
is it possible with software key on CUCM create icon on phone for call farward. exc: when i exit from office i want click icon on phone and all calls forward number 4555 and when
06-07-2022 04:54 AM
there is fwd All on Cisco 7821 . but i want to configure only click 1 time forward 4555 number.and when return 1 time click delete forward
06-07-2022 05:22 AM
No this is not possible. What you best can achieve is to have a speed dial defined with the number that you'd like to CFA to and then use the Fwd All button in combination with this SD to turn CFA on, then when you'd want to turn it off you'll only press the Fwd All button again.
06-07-2022 08:09 AM
The only option is the one which @Roger Kallberg mentioned.
you can also try the no answer forward so if you don’t pickup the call based on configured no Nader timer it can be forwarded to desired extension.
Forward no answer can be configured from self care portal or can be configured by the admin.
06-08-2022 12:16 AM
Thank for reply. is it possible create softkey No answer or not at office?
06-08-2022 12:19 AM
No you can’t..
